01-21-2009, 02:15 PM | #1 |
thinking bout bagging my truck
does any one know if it would be possible or easy to lay frame in my step side that has leaf spring without c notching the frame
01-21-2009, 02:21 PM | #2 |
Re: thinking bout bagging my truck
with daytons, possibly.
01-21-2009, 02:28 PM | #3 |
01-21-2009, 02:39 PM | #4 |
you dont without a cnotch
01-21-2009, 02:43 PM | #5 |
ok will the leaf spings let it go all the way down
01-21-2009, 02:43 PM | #6 |
Living Legend
Not that it matters on the question but what year is your truck? Here is your issue with what you are asking, 20” wheels and say a 2” side wall tire, that grantees that your axle will never go closer then 12 in from the ground (radius of wheel + tire side wall)and your solid frame cannot pass through your solid axle… so if you want your rear frame on the ground you will need to figure the distance from the bottom of your frame to the inside of a notch needs to be equal or greater to the previous mentioned 12”.
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony |
01-21-2009, 03:00 PM | #7 | |
wow ok, its a 68 and maybe i should just re-think the laying frame thing and just try and get it pretty low |
01-21-2009, 03:02 PM | #8 |
Why not rethink the notch and cut it up.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
01-21-2009, 03:02 PM | #9 |
Living Legend
just keep in mind the lowest the frame will go is botoming out on the axle... gl
01-21-2009, 03:05 PM | #10 |
01-21-2009, 03:05 PM | #11 |
ok bro thanks, but if i do c notch the frame the leaf springs will work ok, and will baggs help at all for wheel hop cause whenever i get on it the rear end hops like crazy
01-21-2009, 03:11 PM | #12 |
If you want to lay frame you should think about 4 linking the rear. You will need a step notch, a c notch will not get you there. Also you will need to do some mods to the front otherwise the first thing to touch the ground will be the a arms.
01-21-2009, 03:20 PM | #13 |
coo, i think i will go to the local bagg shop and see what it is going to run me
01-21-2009, 03:23 PM | #14 |
Living Legend
There is a special runnin on bags and front brackets stickyd on the suspension forum
01-21-2009, 03:24 PM | #15 |
coo ill check it out, all i want is front and back
01-21-2009, 03:28 PM | #16 |
i have a cheap air setup in the classifieds. valves, compresssors, tank.
01-21-2009, 11:24 PM | #17 |
Texas Big Wig
Are you thinking about doing this yourself or having it done ???
If it were me I would loose the leaf springs & either go with a trailing arm set up or a 4-link |
01-21-2009, 11:52 PM | #18 |
01-22-2009, 01:04 AM | #19 |
Happy to be here
No, there is nothing wrong with leaf springs. It is a little easier to do the trailing arms, but I sure wouldn't "convert" your truck.
01-22-2009, 12:09 PM | #20 |
accepting donations
Edflores, what section are they in?
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
01-22-2009, 12:25 PM | #21 |
01-22-2009, 12:39 PM | #22 |
Texas Big Wig
Like N2TRUX said, leafs dont suck, its just easier without them
You just have to decide how much work you wanna put into it (if you build it yourself) or how much you wanna spend (if you have someone do it) but either way you are gonna have to spend money & it will take more time before you are rolling low If you just want it to be low, but not spend a bunch of time then I would stay away from laying frame... FAR away The rear is not the hard, or all that expensive part to get to lay frame, its the front, you have the problem of your cross-member & LCAs hitting the ground first, so either you have to buy a PorterBuilt DropMember, or mod the fire out of your stock cross-member, or Z the frame (the dropmember being the easiest & to me worth the money) Here is a thread with some different trucks in it that show about the lowest you can go without tons of work http://67-72chevytrucks.com/vboard/s...ht=stock+floor |
