Old 01-21-2009, 09:25 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Started 2wd swap
Passenger side brackets are off. I will try and knock out the driver side tomorrow. I drilled a hole in them and then brought out the anlge grinder. It makes it alot easier that way. Now I just have to figure out how to do it at the junkyard. I have alot of ideas and tips i just need to try it. On to the pics:
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-24-2009, 10:41 AM   #2
softballnrd27
Re: Started 2wd swap
Got the rear brackets taken off. I should be able to get the rear 2wd brackets on Sunday. I painted the frame grabber green. It should look pretty good when the bed and stuff is back on.
Pics:
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-24-2009, 11:10 AM   #3
87Bob
What are you doing? 2wd to 4wd? or 4wd to 2wd? That green is electric! Wow! You'll get noticed!
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 01-25-2009, 12:44 AM   #4
softballnrd27
4wd to 2wd. I plan to paint the 383 grabber green, the engine compartment gloss black and the outside will be Olive Drab Green with a Black eagle, globe and anchor on the hood.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
