Old 01-21-2009, 09:39 PM   #1
joe231
joe231's Avatar
I need Motor mount HELP!!!
I am trying to get new motor mounts for the 283 in the '66.....
everywhere I look says #2282.
I got a pair and the passenger side will work fine but the drivers side interferes with my factory power steering bracket.
I can't find any that look like the ones on it.
here is what everyone sells
and here is what I have
as you can see the ones I have fit with the power steering bracket, and the new ones are just too long and too square. I realize that I can modify the bracket or the mount.....
I would like to know if anyone else has encountered this problem.
TIA
it seems my battle with the universe is on
CHEVY ONLY
Old 01-22-2009, 12:59 AM   #2
Captainfab
60-66 Nut
Re: I need Motor mount HELP!!!
It's been a while since I've used those old style mounts, but I'd say you're going to have to modify one or the other. I'd probably mod the mount.
Old 01-22-2009, 01:19 AM   #3
joe231
joe231's Avatar
that is what I was thinking.....i'll get the porta-band after it soon...
i'm guessing it was a design change by the after-market suppliers
thanks Capt.!
BTW, what mounts do you use?
CHEVY ONLY
Old 01-22-2009, 02:18 AM   #4
Captainfab
60-66 Nut
I usually use the '73 and up style mounts. Some say they're ugly, but I don't think so....plus they're a better design from a durability viewpoint IMO.
Old 01-22-2009, 02:07 PM   #5
502tripower
502tripower's Avatar
Not to mention you can then buy headers for 73' up that fit better.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-22-2009, 05:45 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Did the rubber break on your old mounts? I never saw one with factory p/s. If that is all that is needed you can probably get www.steelerubber.com to revulcanize them. I think you will have to call on that one though.
Plus I didn't have any problem with later headers with the stock mounts. all you have to do is ask for a 72 year model.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-23-2009, 12:23 AM   #7
joe231
joe231's Avatar
yeah the rubber on one is oil soaked and torn loose, the other one is just loose.
these new mounts are like 8 bucks apiece, so i have no heart-burn about mod'n' 'em
yeah i got the power steering brackets from Captainfab. they are for the short water pump, it tucks the pump low and tight to the block
CHEVY ONLY
