Old 01-21-2009, 10:03 PM   #1
friscocrownie
Oil Gauge Problem
My Oil Gauge (84 305) hasn't been working for a while, it used to peg at 60 and when I turned the key on go to 0 and then back all the way to 60+, so I thought it was the pressure switch (bell shaped by the distributor). I replaced the pressure switch today and now the gauge just stays at 60+(pegged) always no matter what, I checked the wire and it seems fine, any other ideas on what could be wrong? Any thoughts/ideas would be greatly appreciated! Thanks!
friscocrownie is offline   Reply With Quote
Old 01-21-2009, 10:08 PM   #2
Longhorn321
Size Matters
Longhorn321's Avatar
Re: Oil Gauge Problem
My guess (guessing cause I don't know how that switch is wired) is that you either have an open circuit or a short circuit to ground. Disconnect the wire and see what the gauge does. You may also have an incorrect/faulty new part.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 01-22-2009, 09:58 AM   #3
James McClure
One shot, one kill.
GM pressure gages and temp gages, open circut = 0 psi or temp. Grounded = max reading+. Fuel gagesn are reversed. Open circut, max reading+ and grounded = empty. It wouold seem to me that the fact that frisco's gage changed what it was doing, even if it's incorrect would tell me the sender and wire are ok, but only to a point. Gage wire could be grounded inside the cab. The gage itself OR the resistor block on the gage could be bad, printed circut or connector plug on the dash could also be a problem. Check everything you can with an ohm meter with the key OFF or battery disconnected. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-23-2009, 09:00 PM   #4
friscocrownie
Thanks for the tips, is it worth trying to replace the gauge next?
Old 01-23-2009, 10:44 PM   #5
Longhorn321
Size Matters
Did you disconnect the wire and see what happened?
...WOOOO HOOOO!!!!
Old 01-23-2009, 10:45 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
you could always get a aftermarket oil gauge from any parts store and mount under the dash or in the factory position
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-31-2009, 06:40 PM   #7
friscocrownie
Sorry for the late reply, I finally was able to check what would happen with the wire connector pulled off the sending unit, the results were the same i.e. the gauge is pegged at 60 now....any ideas on what else to check?
Old 02-01-2009, 12:50 AM   #8
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Sounds like your wire is grounded, could it be pinched under the valvecover or
something else?
heavychevy79 is offline   Reply With Quote
Old 02-01-2009, 01:20 AM   #9
Longhorn321
Size Matters
Yep. Sounds like your wire is grounded or your gauge is bad.
...WOOOO HOOOO!!!!
Old 02-01-2009, 12:21 PM   #10
friscocrownie
Great, thanks guys I appreciate the help!
Old 02-02-2009, 11:54 AM   #11
Longhorn321
Size Matters
Well did you fix it? What have you found?
...WOOOO HOOOO!!!!
Old 02-03-2009, 11:37 PM   #12
friscocrownie
I haven't had a chance to tear back in to it yet, but as soon as I do I'll definitely let you know.
Old 02-03-2009, 11:56 PM   #13
Longhorn321
Size Matters
We'll be here.
...WOOOO HOOOO!!!!
Old 02-04-2009, 03:39 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ya x2 thats just my .02 cents bud.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
