Old 01-21-2009, 11:36 PM   #1
drewfever1020
ay ay ay?
what would a 456/486 cam do to my truck?
drewfever1020 is offline   Reply With Quote
Old 01-21-2009, 11:45 PM   #2
custom72c20
custom72c20's Avatar
Re: ay ay ay?
Need more info on your motor, cam, etc... The more info the better. Thanks
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 01-21-2009, 11:49 PM   #3
drewfever1020
Re: ay ay ay?
i got a small block 350
Old 01-22-2009, 12:47 AM   #4
custom72c20
Re: ay ay ay?
stock everything? What heads, intake, carb? What are the rest of the specs on the cam such as lobe center and duration?
Nick
Old 01-22-2009, 01:20 AM   #5
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Re: ay ay ay?
Make it out run mine. hehehe
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 01-22-2009, 06:05 AM   #6
Re: ay ay ay?
If it has all the other dynamics I`m thinking,it would make other engine mods necessary as well as a higher stall converter.Take into consideration your rear end ratio and desired rpm range for where you want your power.There`s more to it than slapping a cam in once you go beyond a mild grind.
Old 01-22-2009, 09:57 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: ay ay ay?
if you have a stock 350, with a stock automatic, and the standard 3.07 gear out back....
it'll make you hate driving your truck
