Old 01-22-2009, 02:27 PM   #1
blazntn
Disc Brakes
Well I cant think of a good way to change my 6 lug over to 5x4.75! So I am going to buy new drop spindles and disc kit. Just wondering who are some of the best companies are to look into. Also what kinda money am I looking at?
Brad W
blazntn is offline   Reply With Quote
Old 01-22-2009, 03:16 PM   #2
XXL
Señor Member
XXL's Avatar
Re: Disc Brakes
I'm not aware of any turnkey kits that will get you to 5x4.75. There are several suppliers who can get you to 5x5. If you're set on 5x4.75, I suspect you'll need to have your rotors drilled. Or, depending on what other mods you may be interested in, you may consider replacing the front clip (I'm not a fan of the MII front end kits for our trucks because of the weight, but they generally are 5x4.75).
XXL is offline   Reply With Quote
Old 01-22-2009, 05:55 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: Disc Brakes
X2...I pressed out the old studs, drilled my rotors for a 5 on 4.75 pattern, and pressed in new studs.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-22-2009, 06:02 PM   #4
blazntn
Re: Disc Brakes
Well I am set on the 5x4.75 I am running the C4 rearend. I already have the dropmember so the MII is out. I am probably going to just redrill. Mcgaughy offers a 13" 5x4.75 but it is pricey!!! Just looking for a reasonable way to do it. Wish I could comvert mine to 5 pretty easily!
Old 01-22-2009, 09:20 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc Brakes
What wheels are you going to run? You can have two different bolt patterns. If the lugs aren't exposed it won't matter.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-22-2009, 09:47 PM   #6
XXL
Señor Member
XXL's Avatar
Re: Disc Brakes
Or drill like vin63 and you're all set.
As for wheels, do you really mean a 13" wheel???
Old 01-22-2009, 10:13 PM   #7
blazntn
Re: Disc Brakes
I dont know what wheels I will run. I currently have six lug so I am going to have to change to 5 lug then drill it. Just wondering if there is a way to do this without buying all new stuff? If not who offers the front drop spindle/disc kits?
13" Disc are offered by Mcgaughy in the 5x4.75 pattern. They are expensive!
Old 01-22-2009, 10:56 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Disc Brakes
Use the '81-'87 truck light duty(1" thick rotor) spindles and the '89-'92 Camaro 1LE rotor. These are available as a drop spindle as well. Direct swap and gives you the 5x4.75 pattern. Depending on the year model of your truck, you will need to update to the '73-'87 ball joints/tie rods, but they likely need replacement and the late model parts are cheaper...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-23-2009, 05:47 PM   #9
blazntn
Re: Disc Brakes
The truck is a 69. So are you saying I can run the new model drop spindle then and the car disc. just have to change ball joints. Sorry for being
Old 01-23-2009, 06:08 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Disc Brakes
Yes. You will need to change upper/lower ball joints and inner/outer tie rods to the '73-'87 parts. If you had a '71-'72, you could get away with just uppers and outers. I am also working on a super cheap/easy way to upgrade to Corvette C5 front brakes as well, but I haven't finalized it yet...
-Chris
Old 01-23-2009, 11:28 PM   #11
blazntn
Re: Disc Brakes
Well I will hold out for that!!! Since I am running the C4 rear. What stuff should I start picking up?
Old 01-24-2009, 01:16 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc Brakes
Originally Posted by gringoloco View Post
....I am also working on a super cheap/easy way to upgrade to Corvette C5 front brakes as well, but I haven't finalized it yet...
You have my attention
Articles-
"Refining Sierra"
Old 01-24-2009, 04:22 AM   #13
quickchevy
quickchevy's Avatar
Re: Disc Brakes
Classic Performance Products has a 5 on 4 3/4 kit.
quickchevy is offline   Reply With Quote
Old 01-24-2009, 09:24 AM   #14
502tripower
502tripower's Avatar
Re: Disc Brakes
As quickchevy says CPP does have a kit to convert the 6-lug over to 5X4-3/4 using the original spindles but, if you want to use dropped spindles this is the wrought you will have to go.
Well after much research and comparisons this is what I have come up with. I would like to thank gringoloco he helped me out here. The 73-87 2-1/2 drop spindle from CPP uses the A-5 inner bearing that has a 1-3/8" bore. This spindle uses the 1-1/4 rotor with the 5X5 bolt circle. This is the same size spindle as the OEM as well. Belltech has a 3" drop spindle that uses the A-6 inner bearing that has a 1-1/4" bore. This spindle uses a 1" rotor and there for can either be used with the light duty truck 1" 5X5 bolt circle rotor or the Camaro 1LE 1" 5X4.75 bolt circle rotor. There it is. This is the only way that I found to switch from the 5X5 bolt circle to the 5X4.75 bolt circle using the OEM rotors. Hope this helps.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-25-2009, 12:01 AM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Disc Brakes
I'll post more details when I get it together. It should be very easy, and can be very inexpensive if you are willing to do some of the work yourself. I am out of pocket for a little while, but will get back on it ASAP...
-Chris
Old 01-25-2009, 11:10 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc Brakes
Thanks, I have seen several different ways of doing it. I would like to see your approach.
I have no doubt that adding larger calipers on stock rotors is beneficial. I feel that to take advantage of the larger calipers you really need larger rotors too.
Articles-
"Refining Sierra"
Old 01-27-2009, 06:24 PM   #17
blazntn
Re: Disc Brakes
Do you have to run the Belltech 73-87 C10 spindle? What does it take to swap to those balljoints?
Old 01-27-2009, 07:30 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Disc Brakes
What are you trying to accomplish? The ball joint swap is as easy as a stock replacement. The lowers press in- the uppers bolt in. If you are looking at doing the C5 stuff, it will work on a light duty spindle that accepts a stock backing plate, be it stock or drop...
-Chris
Old 01-28-2009, 08:24 AM   #19
blazntn
Re: Disc Brakes
I am just looking for an easy way to have 5 x4.75. I currently have drop spindles with six lug disc brakes.
Old 01-28-2009, 11:36 AM   #20
5150
C10 Club Tennessee
5150's Avatar
Re: Disc Brakes
Hey Brad, ball joints are pretty straight forward, you can rent the tool at one of the local auto parts stores there in town.
Are you running tubular arms with the dropmember?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-28-2009, 01:54 PM   #21
blazntn
Re: Disc Brakes
I am running the stock arms. I did the mod to make them work.
So if I get the Belltechs, and the ball joints. What else will I need to pick up. Can I buy it at parts stores, or do I need to find a wreck?
Old 01-28-2009, 01:57 PM   #22
5150
C10 Club Tennessee
5150's Avatar
Re: Disc Brakes
Brad, you can get it all at the parts store. Just depends on which spindle you use. I'm sure somebody will correct me if I'm wrong, but you buy the ball joint for the year spindle that you are using.
By the way, I called you Monday afternoon, but you weren't home. I didn't tell your wife who or what I was calling for so if you were wondering who the heck it was, it was me
Bryan
www.gmtruckshow.com
Old 01-28-2009, 02:02 PM   #23
blazntn
Re: Disc Brakes
Man I was wondering!!! Give me a call this afternoon. I should be home at 330pm - 4pm
Old 01-28-2009, 02:13 PM   #24
502tripower
Re: Disc Brakes
Just make sure that the spindle that you are using uses a A6 inner bearing. Which is a 1-1/4" bore. This is the same bearing that the 1LE Camaro rotor used and the 81-87 light duty truck. The light duty truck used a 5X5 bolt circle while the 1LE Camaro used a 5X4-3/4. Here is a thread that may explain it better for you. Good Luck
http://67-72chevytrucks.com/vboard/s...d.php?t=319487
98' FXD
2002 2500HD
Old 01-28-2009, 04:35 PM   #25
blazntn
Re: Disc Brakes
Thanks Bro!!!
