Old 01-22-2009, 07:40 PM   #1
au03z71
au03z71's Avatar
Bagging Question:
I've been tearing up the suspension forum lately but I'm trying to get it right:
Do I need a C-Notch if I bag the rear of my truck? I'd like to have around 6" of drop and a level stance. (2.5 drop spindles up front with bags)...
au03z71 is offline   Reply With Quote
Old 01-22-2009, 07:58 PM   #2
mycool72
mycool72's Avatar
Re: Bagging Question:
Im assuming your talkin 67-72 chevy...if so the answer is no and yes...if you just want a little drop no, if you want to go fairly low then yes do a notch...its not rocket science, without a notch your axle will hit the bottom of your rear rails...measure between the two, thats the most drop you can possibly get without a notch. Don't forget to allow for travel....if you do the notch, worst case senario is you will have a little extra room.
mycool72 is offline   Reply With Quote
Old 01-22-2009, 07:58 PM   #3
theyammieguy
accepting donations
theyammieguy's Avatar
They look to easy to install so why not?
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-22-2009, 09:23 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
And that should be about 4" minimum
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-23-2009, 07:38 AM   #5
au03z71
au03z71's Avatar
That's what I was thinking.
Old 01-23-2009, 08:13 AM   #6
theyammieguy
accepting donations
I'm gonna weld mine in since I pull a trailer.
David Crockett
