Old 01-22-2009, 08:12 PM   #1
mikeupnorth
Question 67 2wd SWB, Bags or Coils?
My son & I are doing a 67 Chevy SWB 2wd project and have reached the point we need to drop the rear end 4"-6". We are considering Bags however this is a very low budget build. What is the least you have to buy/spend to use bags on the rear? Thanks for the help.
mikeupnorth is offline   Reply With Quote
Old 01-22-2009, 09:47 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: 67 2wd SWB, Bags or Coils?
If you have a trailing arm rear, you simply can bolt bags in place of the springs, install schraeder valves, and fill them to ride at the 4-6" drop. Then you could adjust it if you ever had a load to haul by adding air and then after hauling let some air out...So just the cost of the bags and valves.
The real expense is in the air management and valves if you plan on adjusting the bags often. Compressor (s), valves or valve manifold, air tank, fittings, lines, gauges, controller....ads up in a hurry.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-23-2009, 08:39 AM   #3
Andy4639
Old member
Andy4639's Avatar
VA72C10,
If you have a trailing arm rear, you simply can bolt bags in place of the springs, install schraeder valves, and fill them to ride at the 4-6" drop. Then you could adjust it if you ever had a load to haul. So just the cost of the bags and valves.
What size bag and is there a kit for this?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-23-2009, 10:56 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by Andy4639 View Post
VA72C10,
No kit as they truly just bolt on to the trailing arm. Slam specialties RE7, or Airlift D2600 bags work very well according to several on here. There are also several others including firestones and Air ride tech ones that work. If you check out any of bagged posts there are pictures with the bag bolted on at the bottom to the trailing arm....the only drilling is making room for the air fitting at the top.
Old 01-23-2009, 12:09 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thanks I'll check into it.
Old 01-23-2009, 06:09 PM   #6
nds1968
nds1968's Avatar
Yes there is a kit from CPP $446. http://www.classicperform.com/Store/...k/6372FRAR.htm
nds1968 is offline   Reply With Quote
Old 01-23-2009, 06:46 PM   #7
OARNGESI
OARNGESI's Avatar
Originally Posted by nds1968 View Post
is that only a 3 or 4 inch drop or am i reading it wrong
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-23-2009, 07:02 PM   #8
big_al_71
big_al_71's Avatar
I really like the idea of the air bags but this is what I would do if I was on a budget....
http://www.earlyclassic.com/home.aspx part number 02-6372-6r 6 inch rear lowering springs $100.00 plus freight and you are done.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-23-2009, 07:11 PM   #9
Andy4639
Old member
Andy4639's Avatar
I have the truck lowered now with springs. I just didn't think there was a bolt on for air bags.
Old 01-23-2009, 08:29 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
That CPP kit isn't needed with the brackets and is overpriced. You can get two bags for under or around 150 plus shipping and two shocks for $30 each (if you need lowered shocks and haven't already installed those) Plus a couple schraeder valves and a short length of hose to make the fillup easier and you're riding on air in the rear for under 250.
Old 01-24-2009, 03:07 AM   #11
VA72C10
VA72C10
VA72C10's Avatar
Here's a really good post about bags (one of many) and a picture of bags on Trailing arm rear
http://www.67-72chevytrucks.com/vboa...d.php?t=183457
