Well, I got these kick panels trimmed up and painted, and replaced the speakers and put it back in and the e-brake hits the speaker! Anyone have any suggestions besides hacking off the end of the ebrake handle? I should have checked first I guess but it states that these should fit for a '67-72. They don't. I found it's almost impossible to dim your lights as well. I've been trying to get a hold of custom autosound, but they aren't answering. Someone had to have installed these with too many modifications.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 01-22-2009 at 09:04 PM. |
![]() Join Date: Feb 2001
Re: what do I do now?
Boy...thats a bummer!
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Under Construction
I have not looked at the ebrake mounting in awhile . Can it be shimmed on the right side or vice versa to make it horizontal to the dash?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
accepting donations
I didn't even think about the dimmer switch.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
![]() Join Date: Nov 2004
Mine has been sitting unscrewed to the floor for quite some time. If I ever get around to it, I'm going to cut out the section of floor it screws into and move it over a couple inches.
Not sure what to do about the e-brake cable, I took mine out of the truck a LONG time ago.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
can the ebrake handle be bent up any?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Bending that thing would be interesting, and I looked at shimming it - it looks to be a lot of work - does anybody know if the lever can be adjusted so that when completely off, it sits closer to the seat, so that it would clear the speaker? Right now it would only need a couple of clicks to be all the way off.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 01-22-2009 at 10:22 PM. |
its all about the +6 inches
can you mount the speaker on the backside of the panel?
I might be able to, but then I wouldn't have anything to protect it. But that's a thought. I'll have to check that. I'm a little cheesed off that the manufacturers/retailers don't say anything about possible problems in the '67's/'68's with the ebrake.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 01-22-2009 at 10:52 PM. |
they don't mention that you can't use the E-brake on 69 - 72 either. It's not a very well thought out product. 1/2 the aftermarket accesories are like that.
accepting donations
You would think that with the normal amount of slack in an e brake cable that a couple clicks would be off
Old member
How deep is the speaker? Can you mount the speaker inside the panel and then leave the grille off? Use some light cloth to cover it.
Another is get under truck with e brake off and tighten up cable good so the brake is off when the handle is against the speaker. Not knowing if either of these methods would work since I can't look at it but it's a starting point for you. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#13 |
Junior Member
I just had my vendor refund my money and they paid shipping back. They are aware of the problem they are just hoping you do not mind modifing your truck.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#14 | |
Moderator
![]() Join Date: May 2007
You can however use the E-brake with no problem on the 69-72's. |
#15 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
That sucks man, good luck figuring something out.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#16 |
![]() Join Date: Sep 2007
I got the ones from LMC too, The pass side doesnt fit very well but a demel took care of that. My E-brake handle though clears just fine (1967) but that dimmer switch is impossable to get to with work boots on. I think Ill move it to the righ a couple inches before installing the carpet and insulation padding
1967custom |
