Gauge Interchange Questions
Does anybody know what gauges from what years will swap with others? I have a 76-77 Tach cluster, and will be looking for NOS or super nice original GM pieces.
Here are my thoughts so far, please correct me when needed. Oil Pressure gauge can only be from a 73-77, because of it being mechanical, or is 73-75 out for some reason? Volt gauge from a 76-up Temp, Fuel, Tach, and Speedo gauges from any 73-87(91)? I am really hesitant about putting one together, but I figure I can use the info if I decide to. Thanks
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
Re: Gauge Interchange Questions
Here's some good info
http://www.73-87.com/7387garage/inte...achometers.htm |
Yeah, I have that but it doesn't answer any of the questions I have.
#4 | |
Everything you've said is correct, however, in 80 or 81, the look of the gauges changed. Functionally, things will interchange, but the look will be different. Also, 73-74 had no blue lines on the speedometer and tach like later clusters do.
1977 GMC Sierra Grande |
Happy to be here
![]() Join Date: Mar 2000
It really depends on how picky you are. There are different configurations for each year as well as changes from year to year. If you want to have a "correct" dash for your truck, get pics from brochures, etc to determine exactly what combo is correct.
Cheyenne Super
Bump
Did you read the tech articles My dad put together years ago? All the info you need should be in there. If you do swap around some gauges and stuff in there only a true expert on these clusters will notice when its in the truck.
73-75 76-77 78-79 Were all their own years. 80 up are all interchangeable except 1980 was still the old Font on the gauges and 73-80 had a 100mph speedo. 81up had a 85mph speedo but I prefer the 81 up Font on the gauges better then the earlier years.
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks ![]() Last edited by crossy's son; 02-05-2009 at 07:57 AM. |
#8 | |
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks ![]() |
