01-23-2009, 11:44 AM | #1 |
4 valve system
Anybody ever seen a 4 valve system utilized? Basically just a common fill and dump for the front and a common fill and dump for the rear? I'm not really interested in being a switch maniac. I just want a good ride and a mean stance with the ability to alter ride height.
Thanks |
01-23-2009, 11:47 AM | #2 |
Living Legend
Re: 4 valve system
yeah i have seen them around town and what not here is a link with a lill bit about valves and being able to run 4 wheel indepentand and 4 valves http://67-72chevytrucks.com/vboard/s...83#post2789983
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony |
01-23-2009, 02:31 PM | #3 | |
Señor Member
Re: 4 valve system
01-23-2009, 05:53 PM | #4 | |
Re: 4 valve system
01-23-2009, 06:03 PM | #5 |
Re: 4 valve system
yes, but they are pretty close to the same price as a solenoid valve ... sooooo
01-23-2009, 06:42 PM | #6 |
Señor Member
Re: 4 valve system
and without the control.
01-23-2009, 06:50 PM | #7 |
Re: 4 valve system
check valves at ace hardware are around 10 bones a piece..........
CHEVY ONLY |
01-24-2009, 01:00 AM | #8 |
Re: 4 valve system
I wouldn't advise putting the kinds of pressures seen in a bag when it is being compressed by a 3,500 lb truck on a $10 check valve ... but that's just me.
01-24-2009, 01:18 AM | #9 |
Re: 4 valve system
if they are rated for 200-250 psi working pressure, burst strength is typically at least 3 times that. The factor of safety, i believe is somewhere between 3 and 5....but I can't find the page right now to get the specs....
but i agree, it is not much in the way of savings, and the loss of function is probably not worth it......
CHEVY ONLY Last edited by joe231; 01-24-2009 at 01:20 AM. |
01-24-2009, 01:58 AM | #10 |
Re: 4 valve system
3X safety factor on all 316 Stainless Steel fittings by Parker Hannifin ... can't say for import variety from Ace Hardware ...
01-24-2009, 08:26 PM | #11 |
Re: 4 valve system
6 valves or nothing, the weight transfer is def too much to put on a check valve...were talking about your life here!
01-25-2009, 02:54 PM | #12 |
Re: 4 valve system
I ran 4 valves on my 88 for years and drove it daily. It It had hardly any air transfer in corners.But I still have my front sway bar and stiff slam ES-72s.
You could try it and if you dont like the way it drives. Just add more.Youre not going to crash cause youre truck leans in corners. |
01-25-2009, 03:08 PM | #13 |
Señor Member
Re: 4 valve system
So if I pull out 4 of my 8 valves, I'll no longer be able to crash?
With 4 valves, the lean will likely be significantly more than even a stock vehicle with stock suspension. Rubbing/cutting tires is not a good thing. Increasing the body roll characteristics beyond what the factory thought was safe is not a good thing.
01-25-2009, 04:38 PM | #14 |
Re: 4 valve system
I didnt mean you wont crash. But the lean wont be significant enough to be the cause if you know how to drive.Most of these old trucks get driven with old wore out stock suspension and lean way more than a rebuilt and bagged with four valve suspension ever will.
I just know from my truck. Mine drove great but not everyones will. |
01-25-2009, 05:46 PM | #15 |
67-72 parts collector,…
Re: 4 valve system
OK,... say you do install check valves in-line to the bags. You hit the fill button. Air goes to the bags. Air will not transfer because of the check valve. Now,... how do you let the air out? The check valve keeps the air from transfering back out of the bag.
4 fills. 4 dumps. Why not make your truck enjoyable to drive. I'd leave it static before I'd run 4 valves.
01-25-2009, 06:34 PM | #16 | |
Re: 4 valve system
I enjoyed it for about 50,000 miles this way.Most the time about an inch off the ground. |
01-25-2009, 06:40 PM | #17 |
Re: 4 valve system
Redsled04,... I wasn't neccessarily talking to you. Sorry.
Just everyone that says to just install check valves. These check valves just flow "one way".
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-25-2009 at 06:41 PM. |
01-25-2009, 06:43 PM | #18 |
Re: 4 valve system
01-25-2009, 07:26 PM | #19 |
Re: 4 valve system
redsled ... slow down and take a breath ... not every response is directed towards you. relax.
