Old 01-23-2009, 07:17 PM   #1
Ravenmocker
U.S.N. EOD
Ravenmocker's Avatar
Horn Cap Spring, Plunger?????
I read the thread you had regarding how to install a factory wheel with the pin,spring and plastic piece.
The pictures were good however I still do not know how the plunger, spring and plastic piece fit or where they fit? The wheel goes over the signal cancel cam. Does the plunger go in there somehow? I need to know how to put the plunger, spring and plastic piece on the wheel. Do you have any pictures or could you walk me through this simple task? Any one have a picture or diagram of how this pin, spring and small plastic piece fit? Is the pin installed upside down, etc...??
Ravenmocker is offline   Reply With Quote
Old 01-23-2009, 07:38 PM   #2
cdowns
cdowns's Avatar
Re: Horn Cap Spring, Plunger?????
LMC catalogue has good diagram how it goes together
Old 01-23-2009, 08:09 PM   #3
john
member #16
john's Avatar
check this out.
http://67-72chevytrucks.com/vboard/s...d.php?t=304844
john is offline   Reply With Quote
