01-23-2009, 07:28 PM | #1 |
rims
i have a 65 gmc 3/4 ton 4x4 truck , up to what year does the rims fit our year trucks . for example ,- would a 2000 chevy/gmc trucik fit a 65 , . any input would be great . thanks
01-23-2009, 07:56 PM | #2 |
Re: rims
Here is a set of 1998 Chevy take-offs wheels, tires and caps from my '98 Chevy K2500 and I installed on my '66 Chevy C20 Custom Camper lwb fleetside. I purchased a set of 1/2" conversion lug nuts (threads on inside and outside) to accept the black caps on the bowtie caps.
Unfortunately, I am not able to tell you which years are interchangeable, but I know up to '98, at least. Last edited by LILRED66; 01-23-2009 at 07:57 PM. |
01-23-2009, 08:13 PM | #3 |
Re: rims
tony ,they went on with no problem , did they have plenty of clearence in the back , also do you have a set to sell , thanks ,.
01-23-2009, 08:26 PM | #4 |
1961 crewcab
Re: rims
I think the more modern wheels 88-98+ have a more (negative?) offset than our wheels- the center is closer to the outside of the wheel, although as per tonys truck,it looks like they do fit
01-23-2009, 08:40 PM | #5 | |
Re: rims
Thanks for the inquiry. They bolted up with no clearance issues. I don't have a set to sell, but I see them on craigs list frequently. You might check your area for a set. Here is a picture of the lug nuts that are required for the factory lug caps and bowtie caps to be installed properly and securely. The lugs from my '98 Chevy K2500 are 9/16" and the lugs from the '66 Chevy C20 Custom Camper are 1/2", so I had to special order a set of 32 from an online source I found on eBay. They ran about $35.00, plus shipping for the set, but they were worth it to install the factory bowtie caps, which I like better than without them. Last edited by LILRED66; 01-26-2009 at 10:38 PM. |
01-23-2009, 09:35 PM | #6 |
3DrDwn--the 'burb not the band
Re: rims
[QUOTE=jonzcustomshop;3103997]I think the more modern wheels 88-98+ have a more (negative?) offset than our wheels- the center is closer to the outside of the wheel, although as per tonys truck,it looks like they do fit[QUOTE]
the newer trucks have a more Positive offset. I believe this is done on the independant suspension so they can push the mounting plane out a tad to allow for slightly longer control arms and ride quality improvements. a Negative off set is what would be typically called a deep dish or from the lowrider community "full reverse" ( think the wheels that stuck way out that were popular about 10 years ago) Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
01-24-2009, 08:33 AM | #7 |
1961 crewcab
Re: rims
ha ha so it is the negative offset wheels I like, the positive ones remind me of a front wheel drive car..... but I am a child of the 70's and 80's , and that was what was common then.
01-25-2009, 10:10 AM | #8 |
Re: rims
I got a set off of a chrome 08 silverado. I was going to put them on my 66lwb durring the build. I asked my local tire shop if they would fit and he said the 6 on 5.5 pattern would. I have since gone in a diff direction but they are supposed to fit.
