Old 01-23-2009, 08:11 PM   #1
NH 72
12" drums for 72 C10?
I'm trying to locate a source for backing plates to convert my stock rear drums to the '67 to '75 station wagon,taxi, police car optional 12x2 rear drums. Has anyone done this swap and do you know of a source for the backing plates.
TGIF
Chris in NH
NH 72 is offline   Reply With Quote
Old 01-23-2009, 08:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: 12" drums for 72 C10?
Sorry can't help you but would like to know the answer myself. Sounds like a good upgrade for the 71 rear end since I can't afford the disc upgrade.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2009, 05:31 AM   #3
project 67 sub
project 67 sub's Avatar
dont know if it will help or not but i put the whole rear drum setup off a 76 c10 on my 71 or 72 rear end
project 67 sub is offline   Reply With Quote
Old 01-24-2009, 12:09 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
What rear end do you have currently?
What year truck is yours? 72?
Why the switch from the 11" or 12" to the 12x2?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-26-2009, 12:09 AM   #5
project 67 sub
my truck is a 67 suburban with a 71-2 c10 rearend.
the switch was because the original brakes for the 71-2 rearend were no good, and the drums i had off the rearend from my 76 had good brake springs, drums, new shoes, and new wheel cylinders in them so i just switched everything over when i did the rear end swap
Old 01-29-2009, 07:41 PM   #6
NH 72
Thanks for the replies. The truck is a 72 with a 12 bolt, I use it to haul my vintage race bikes and my camp trailer to the track. The rear brakes need overhauling and I'd like to upgrade them. Drums are more effective for trailer hauling / stopping and cheaper then a disc setup. Bigger is better and it's a bolt on, if I can find the backing plates. The rest of the parts are available. If I had the Part numbers then it would be easier to locate them. In the meantime I'll just keep turning over rocks.
Chris in NH
Old 01-30-2009, 03:32 AM   #7
project 67 sub
look at your local recking yards for parts(ie: backing plates etc.). they should all work from a 73-87c10 truck. and 73-91 blazer, jimmy, and suburban
Old 01-30-2009, 10:02 AM   #8
grayw0lf
You could also go the other route... 11 x 2.75" HD rear drums. They're not as tall, but definately wider. There are a few good threads on here w/ detailed donor lists if you search.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 01-31-2009, 10:13 AM   #9
bignbad
bignbad's Avatar
i have a set of rea backing plants off of a '72 k20 unsure of the size of hand i'll later on today.Actualy i have 2 sets 1 0f the '72 eaton rear and the other is off a mid '70's truck 14 bolt ff.I check the size and get back to you.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 02-07-2009, 01:44 PM   #10
NH 72
Hmmm, maybe I need to be more specific. The '67 ?-'75 taxi, police and station wagon heavy duty brakes were a 5 on 5 bolt pattern with 12" by 2" brake shoes. An easy bolt on! They require 12" backing plates and drums. All of the parts except the backing plates seem to be available from local suppliers. I'd like to do this upgrade if I can find the backing plates. I tried to get the part number for them from my local Chevy dealer, but his parts books only go back to the early 80's. It would make it easier to locate or authenticate the plates if I could find that part #. I haven't done a wrecking yard search yet but I will in the near future. If they're un-obtanium then I'll just rebuild my existing set up. Thanks for the replies so far.
Chris in NH
