Old 01-23-2009, 11:59 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
Bagged trucks and longer rubber brake hoses,...
Now that the front of my blazer is on bags,... the front rubber brake lines are a little too short.
At full dump they are stretched "tighter than a fiddle string"!
I don't think the 73-87 guys have this problem. Can I use a factory OEM hose that is longer? (any part numbers?) TXfirefirghter posted that the 3/4 ton 71-72 hose is 1 inch longer, (and about $20 each higher priced)
I'm thinking it might be cheaper to switch to 73 calipers and hoses,... but I don't know if they fit my 71-72 spindles OR if the 73 rubber line will bolt up to the 71-72 steel hard line. Any suggestions?
Keith
Convert to disc brakes.
Old 01-24-2009, 12:17 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Bagged trucks and longer rubber brake hoses,...
im pretty sure switching to the 73 up calipers and hoses will remedy your problem
bagged74 is offline   Reply With Quote
Old 01-24-2009, 12:35 AM   #3
70k52wd
Blaze-Air
70k52wd's Avatar
Funny, I'm bleeding you for info, and your asking a question. Hmmmm, starting to get worried here.
70k52wd is offline   Reply With Quote
Old 01-24-2009, 01:04 AM   #4
lolife99
lolife99's Avatar
thanks bagged74.
Keith
Old 01-24-2009, 01:08 AM   #5
lolife99
lolife99's Avatar
I could run them,... I just need an excuse to use them on a disc brake conversion on the '69,... and get new ones for the blazer .
Keith
Old 01-24-2009, 06:59 AM   #6
sick69
sick69's Avatar
Or you could get a stainless braided set from speedway.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-24-2009, 07:25 AM   #7
lolife99
lolife99's Avatar
sick69,... I will check that out.
Keith
Old 01-24-2009, 07:43 AM   #8
sick69
sick69's Avatar
Here are a couple I found on speedway
http://www.speedwaymotors.com/Web-On...ree,23411.html
http://www.speedwaymotors.com/DOT-Ap...Kits,5059.html
Hope it helps
Frank
70 chevy lwb c10
