Old 01-24-2009, 12:29 AM   #1
62 apache
62 apache's Avatar
torsion bar lowering
I was wondering if anyone here could guide me on a inexpensive way to lower the back of my 62. I am planning on cranking down the torsion bars as low as i can and would like the back sit level or a little lower than the front. I have done alot of searches but can seem to find one specific to the torsion front end. Seems like some relocate there shocks some dont some use a adj panhard some dont etc. Thanks ....And yes i will be posting some pics asap
62 apache is offline   Reply With Quote
Old 01-24-2009, 01:11 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: torsion bar lowering
When you crank down the torsions, make some measurements to track how low ya go.....then get new coils for the rear matching your front.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-24-2009, 01:15 AM   #3
62 Bowtie
62 Bowtie's Avatar
cranked my torsion bars with 2&1/2 drop spindles in front and for the rear I changed out the coils
62 Bowtie is offline   Reply With Quote
Old 01-24-2009, 03:40 AM   #4
slepysal
slepysal's Avatar
cranked mine down, and used "cheep" jeep rear springs total cost 20.00
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-24-2009, 02:25 PM   #5
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
slepysal: you got my attention when you used the word "cheep"! are you saying that jeep has a coil spring that is a direct replacement for our rear coils but is shorter? I may have misunderstood.
fleetsidelarry is offline   Reply With Quote
Old 01-25-2009, 08:27 PM   #6
slepysal
slepysal's Avatar
check this post out
http://67-72chevytrucks.com/vboard/s...highlight=jeep
Old 01-25-2009, 09:44 PM   #7
fleetsidelarry
Senior Car Nut
Thanks for the info, I will check it out!
Old 01-29-2009, 11:55 PM   #8
forestb
forestb's Avatar
Do you know how many inches you lowered it with the torsion bars. I lowered mine the same way with 2 1/2 inch drop spindles and by loosening the torsion bards but I have now idea how much I lowered it. Also how does it handle now that you have loosened the bars
forestb is offline   Reply With Quote
Old 01-30-2009, 02:19 AM   #9
slepysal
slepysal's Avatar
I think I got about 3" on mine It handles ..............well like an old truck.No realy it handles fine
Old 01-30-2009, 04:05 AM   #10
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
I really like the Jeep rear idea.
http://cgi.ebay.com/ebaymotors/rear-...Q5fAccessories
Can the Jeep front springs be used for the same purpose?
I'd like to see pics of the torsion bar trick.
Can you still use the stock spiindles?
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 01-30-2009, 10:01 PM   #11
forestb
forestb's Avatar
Speaking of torsion bars. Mine are hitting a trans crossmember that the previous owner fabricated? so that a 350 trans could be installed does anybody know of a trans crossmember that clears lowered torsion bars and also hold up a 350 trans? I can't seem to find anybody that sells a crossmember for a 62 c-10 1/2 tun.
Old 02-13-2009, 01:43 AM   #12
rss396
rss396's Avatar
I have the CPP 4 inch drop springs in the rear of mine. Wish I would have gone with the 5 inch and cut the top off my bump stops. I cranked down the torsion bars to match the rear. I do not know who makes drops spindles for the 60-62. Put my name at the top of list for a set. If you install the rear drop springs 4 or 5 inch and do not crank the torsion bars down and you will have the rake.
1950 Chevy 1/2 ton 283 Mustang II
1961 SWB 2x4 235 six
2007 Silverado 1/2 ton Z71 4x4
1968 Camaro SS 396 / 502
rss396 is offline   Reply With Quote
Old 02-13-2009, 12:15 PM   #13
slepysal
slepysal's Avatar
I got my drop spindels from Maguphys ( sp ) cpp has them so does early classic. Make sure you get the 60-62 and not 63-66
Old 02-13-2009, 02:29 PM   #14
Corts60
Just here to tinker
Corts60's Avatar
Hey got a question: Can you still use the factory drum brakes with the new drop spindles?
Old 02-13-2009, 07:07 PM   #15
slepysal
slepysal's Avatar
as far as I know no you can not.
Old 02-13-2009, 08:22 PM   #16
Slingnutt
Slingnutt's Avatar
Wow..I was just out cranking mine down and came in and saw the thread. Mine doesn't look like it moved much. I plan on going with bags anyway. Can I just take the bars off and weld cups on? I'm pretty sure it's not that easy, but in theory... I'm gonna cut the springs in back and crank down as much as possible till I get my kit.... any suggestions would be appreciated...62 model
The very existence of flame-throwers proves that some time, somewhere, someone said to themselves, You know, I want to set those people over there on fire, but I'm just not close enough to get the job done~~~George Carlin
When you step on the brakes your life is in your foot's hands~~~George Carlin
Have you thanked a VET today???
Slingnutt is offline   Reply With Quote
