Old 01-24-2009, 11:22 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
What transmission gasket / filter question
I'm going to replace my gasket and thought I'd put a fresh filter in too.
Apparently there are a couple different styles of filters. screen type and felt.
What is better?
The gaskets had a couple of choices too. One was a rubberized cork (felpro) and one was just flat rubber (NAPA).
I'm looking for a good non-leaking seal, and the cork that's on it now seems to be seeping. (it looks alot thicker than the ones I've seen at the store)
Any suggestions/tips?
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-24-2009, 11:34 AM   #2
justcuz
justcuz's Avatar
Re: What transmission gasket / filter question
Most filters are now the felt looking type. They filter better than the fine screen. I recently started using the rubber gaskets on the trans pans. The cork ones can seep through the gasket and also if not tightened evenly, will leak. The rubber or hard paper ones work better. Just do not overtighten the rubber so it squeezes out past the pan sides. Tighten the bolts up snugly to the pan, then from the centers out give them about a 1/4 turn more. I use a stubby ratchet and just one hand on the final tightening. I usually stick the gasket to the pan and put grease on the sealing side to the transmission so it can be reused a few times.
justcuz is offline   Reply With Quote
Old 01-24-2009, 12:16 PM   #3
Sport/Truck
Sierra Grande Club
One for the rubber & felt filter. Anyone else?
Old 01-24-2009, 12:25 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
x2
Member Nr. 2770
Old 01-24-2009, 04:33 PM   #5
BP68
BP68's Avatar
x3
and if possible torque your pan bolts for added insurance.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 01-24-2009, 05:55 PM   #6
eseaton
eseaton's Avatar
x4 for felt and rubber
eseaton is offline   Reply With Quote
Old 01-25-2009, 10:21 AM   #7
Sport/Truck
Sierra Grande Club
Originally Posted by BP68 View Post
x3
I will, I think I have the torque spec somewhere.
Are you using anything on the pan to glue/seal it other than justcuz?
s/t
Old 01-25-2009, 01:17 PM   #8
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
You're better off installing the gasket dry.
Over time, the metal around the bolt holes gets pulled up from overtightening. Take a ball peen hammer and peen the pan rail back down flat around the holes (I do this over a corner of the vise for support). With a flat pan rail, a dry gasket should seal up fine.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
