What bracket is this
Since this bracket came off a date coded 1977 350ci Chevy, & the PO told me the engine came from a Chevy truck, I thought I'd ask what it is.
It was attached to the one side of the engine block at the engine mounting holes. Any ideas??
1997 GMC Sierra Ext 1965 Mustang |
![]() Join Date: Dec 2008
Re: What bracket is this
The bracket goes between the engine block and the motor mount clam shell. There is supposed to be one for each side of the engine. The rod on the bracket connects to the two bolt holes on the cover over the torque converter bolted to bottom front of the transmission.
Is this for 2wd, 4wd or both?
thanks
yeller
I have never seen one of those on any 2wd I have owned (which is ALL I have owned).
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I've had those support struts on several Turbo 400 equipped 4wds. The flywheel covers were cast aluminum.
So this is in fact for a 4wd truck, 73/87 models?
Kid's Mechanic
Yes,only seen them on 4X4s
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Ditto, 4x4 only application.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
thank you.....
Always a work in progress
Are they neccesary? I have them on both sides but I am going to 2wd, will I still need them?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
scrap pile!!!!!!!!!!!!!!!!!!!!!
Georgia Boy
You can use them for a torque strap..
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
#13 |
They aren't needed on a 4x2, you could sell them to a 4x4 owner, but most of them have probably scrapped them by now.
#14 |
Wide n'Low
![]() Join Date: Jan 2007
I have the brackets on my untouched 78 2wd swb small block. It does not have the support rod, and I am not sure if it had the hole for it or not. When I disassembled the truck they did not go back on. I will look at them and see if the are the exact same or not. I am fairly certain, this truck had never had the engine out as it was a one owner whom I knew. Could be wrong though, wouldn't be the first time
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
