Old 01-24-2009, 02:58 PM   #1
greystoke
carrier bearing
Has anyone every changed out their carrier bearing? It looks like it would have to be pressed off and pressed back on, any input??
greystoke
greystoke is offline   Reply With Quote
Old 01-24-2009, 03:11 PM   #2
69gumby
69gumby's Avatar
Re: carrier bearing
http://67-72chevytrucks.com/vboard/s...d.php?t=324948 If I did this right this is a thread I started when I changed mine last week. If it doesn't work the title was one of those parts nobody sees or cares about till it's broke.
Hope this will help.
69 sweet long fleet, David
69gumby is offline   Reply With Quote
Old 01-24-2009, 03:11 PM   #3
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: carrier bearing
Unless you have a press, you aren't going to get it done right. Do yourself a favor, and have a driveline shop do it for ya. Well worth the fifty bucks it will cast ya.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 01-24-2009, 03:14 PM   #4
69gumby
69gumby's Avatar
Re: carrier bearing
One more thing, buy an American made bearing. They cost about twice as much but if you only have to do the job once you win.
Old 01-24-2009, 03:27 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: carrier bearing
like said above, if you don't have a press, then don't bother. remember that shaft spins 2500 - 3500 RPM when you are on the freeway... you'd never hit your crank shaft with a hammer, so don't hit the shaft with one either.
Old 01-24-2009, 03:33 PM   #6
69gumby
69gumby's Avatar
Re: carrier bearing
X2 NO HAMMERS!!! People get away with it from time to time but use a press if you want it done right.
Also I replace all the u joints while I was at it.
Old 01-24-2009, 03:57 PM   #7
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: carrier bearing
My old one slid off after some PB blaster. I put the new one on using the bolt that comes out when you take it apart. If it hadn't gone together so easily, I would have taken it somewhere to get it pressed on. Definitely don't want to swing a hammer at something balanced.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 01-24-2009, 08:27 PM   #8
70clone
70clone's Avatar
Re: carrier bearing
every time ive done one ive used a hammer you only use a press to get it off they dont press it back on at the shop its real easy to do. here is the write up i did on it. technicaly it was meant to be pressed off, but you wont hurt anything if you do it this way, i just dont see paying someone $50 to do this but then again i run a mobile auto repair business and people pay me $75 to fix there carrier bearings. most of the tim you can just tap the bearing a few times with a hammer and it comes right off. It will take you longer to take it to a shop than it will take you to do the complete job
http://www.67-72chevytrucks.com/vboa...d.php?t=318710
70clone is offline   Reply With Quote
Old 01-24-2009, 09:58 PM   #9
Longhorn Man
Re: carrier bearing
When you do something for a living is one thing, when you have no clue how it's done... that's another all together.
Old 01-24-2009, 11:06 PM   #10
70clone
70clone's Avatar
Re: carrier bearing
true but the carrier bearing isnt that serious.its barely even on there. its not like a front wheel bearing on a front wheel drive car.all im saying is it can be done with basic hand tools you cant destroy anything except the old bearing and as far as bending it you have more of a chance hurting the driveshaft doing a basic burnout.
Old 01-25-2009, 12:00 AM   #11
Longhorn Man
Re: carrier bearing
yet we get kerfagled driveshafts all the time with the customor saying "I was trying to take off this hanger with a hammer..."
Old 11-23-2014, 08:38 PM   #12
JonnyC10
Re: carrier bearing
I'm in the process of swapping my carrier bearing now and have it all apart. Does the new bearing have to be pressed on or anything? Its the pedestal type. I have the pedestal and the yoke back on but I didn't think about pressing the beating on til after the fact. Do I need to take it back apart and press it on some how or is it ok?
JonnyC10 is offline   Reply With Quote
Old 11-23-2014, 09:12 PM   #13
brad_man_72
the boat guy
brad_man_72's Avatar
Re: carrier bearing
I always used a driver to put the carrier on but you can use the yoke and bolt to press on the carrier bearing. Its not hard to bend the carrier stub they are supposed to be within .002" of straight. After you get your shaft back together in time, have it ballanced as an assembly.
I've built a couple of thousand driveshafts back when that's what I did.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-23-2014, 09:37 PM   #14
JonnyC10
Re: carrier bearing
Thanks for the reply. So the yoke sits up against the bearing?
Old 11-23-2014, 10:00 PM   #15
sduckworth13
sduckworth13's Avatar
Re: carrier bearing
Do you have a shortbed? I just switched over to a one piece and said good bye to the carrier bearing forever. Cost me 147.00 to switch out the u joints, balance, and have it cut down and welded.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-23-2014, 10:14 PM   #16
JonnyC10
Re: carrier bearing
Yes, short bed.
