Old 01-24-2009, 04:13 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
tell me what to do =-)
ok been posting alot lately which meand next month i get a dedicated tear down weekend..
gonnaa have the front off the ground and want todo everythignwhile im under it..
so ive heard alot lately about changing the drop bracket for my steering etc..
im not of the financial state to do cross over steering..
what can i do to improve my steering dynamics?
and i still cand trun left worth a crap..
what should i do to change that?
is the powersteering itself off? from when i did the axel swap?
what do yall think?
photobucket is being a .. well unpleasent word..
soo i'llpost pictures later
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-24-2009, 04:18 PM   #2
dammitmitchell
the pollock
Re: tell me what to do =-)
any reccomended websites besides photobucket to use for image uploading?
i keep getting rerouted to a spam site.. uggh!
Army vet 02-08
Old 01-24-2009, 07:58 PM   #3
vtblazer
vtblazer's Avatar
Download irfanview and you can load pics directly from your PC.
Not familiar with your current steering issue's but I have the arms to do a cross over for a D60 for sale over on CK5.
vtblazer is offline   Reply With Quote
Old 01-24-2009, 09:01 PM   #4
dammitmitchell
the pollock
corp 10 front from an 84 burban
Army vet 02-08
Old 01-24-2009, 09:05 PM   #5
msgross
msgross's Avatar
I've never had a problem with photobucket...
you can email some pics and i'll post them...
msgross@hotmail.com
I'm interested in your setup since i'm running an 82 corp10...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-24-2009, 10:55 PM   #6
dammitmitchell
the pollock
Army vet 02-08
Old 01-24-2009, 11:05 PM   #7
dammitmitchell
the pollock
i do not turn left well at all.. not goo enough to get into a parkin space..
but i turn right like it's no other.. better then some import cars =-)
so do i need a pitman arm that drops lower? adjust the drag link?
Army vet 02-08
Old 01-25-2009, 12:14 AM   #8
maximum destruction
In House Collision Technician
here are u're 3 choices:
1-buy a drop steering arm for the box
2-buy a s-shaped draglink
3-buy a raised steering block to go under the arm
u only need 1 of these to remedy the problem & the cheapest will be a raising the steering arm with a block although it's probably not as good as the other 2.
MAXIMUM DESTRUCTION
maximum destruction is offline   Reply With Quote
Old 01-25-2009, 08:46 AM   #9
msgross
msgross's Avatar
It probably needs aligned as well then... I bet your steering arm isn't in the right spot on the box or the drag link needs adjusted...
If you find the center position of the steering wheel/box are the wheel straight? Turn it from all the way left to all the way righ and divide in half, that's center...
The raised block on the axle might be the cheapest but I will never attempt to take one off again... can be very very stuck!
I'd adjust your current drag link and if it doesn't work get this dropped one, $150 though...
http://www.offroadunlimited.com/orus...idproduct=4086
The Garage:
Old 01-25-2009, 03:15 PM   #10
maximum destruction
after seeing the pics, it looks as though u already have a drop pitman arm on the box. those springs look like at least 8, if not 10 inchers, so someone has already done something or u wouldn't even be able to hook it up. the secret to getting full steer both directions is to have the draglink almost level horizontally. yes the cone washers on the steering are are a pita & i don't like the extra stress put on the knuckle by the increased leverage the block adds. so i believe an s-shaped draglink is in order.
MAXIMUM DESTRUCTION
Old 01-26-2009, 12:46 PM   #11
dammitmitchell
the pollock
sweet yeah the conical washers have proven to be difficult.. took the last block off with an evening soak of Peanut butter (pb blaster) and whacked it good with a dead blow to loosen off =-)
oo s shaped drap link?
and yeah it's abou t8 inches of lift with the angled blocks under the front and rear =-)
fits those 37's pretty well..
Army vet 02-08
Old 01-26-2009, 12:47 PM   #12
dammitmitchell
the pollock
pitman arm is also Stock..
as far as i know.. i removed the one from teh donor truck to make sure (it was stock) and they r the same
Army vet 02-08
Old 01-26-2009, 04:57 PM   #13
maximum destruction
the arm on the knuckle appears to be stock but the arm on the box is definitely a drop arm, usually good for 4 in. lifts. like stated earlier, the geometry between the 2 arms needs to be level horizontally to reach full throw of the box from left to right.
MAXIMUM DESTRUCTION
Old 01-26-2009, 06:53 PM   #14
msgross
msgross's Avatar
nope, that's a raised steering arm and a dropped pitman arm...
I'll take pics of stock if you want...
The Garage:
Old 01-26-2009, 08:41 PM   #15
maximum destruction
i just noticed that thing doesn't have a swaybar either. does it have a lot of body roll being that high?
MAXIMUM DESTRUCTION
Old 01-27-2009, 02:12 PM   #16
dammitmitchell
the pollock
not too bad.. ive got a sway bar in the corner of the garage... but for "stock" ride height ...i dont corner fast though.. and the springs are pretty strong so the body rolls not bad i can feel it.. but not too bad..
Army vet 02-08
Old 01-28-2009, 12:46 AM   #17
skchevota
skchevota's Avatar
I would make sure your steering is centerd first. turn the wheel from lock to lock and count the turns, then turn back half as many. now see if your wheels are pointing straight. If not the adjust the draglink to point them straight, also make sure the pitman arm is 90 degrees from the frame when the box is center. If all this checks out the you will need an s link. You do really need cross over, but if it is just out of ajustment than that will get you by for now.
skchevota is offline   Reply With Quote
Old 01-28-2009, 02:58 AM   #18
dammitmitchell
the pollock
well was gonna get off my butt and do "the job" today.. but noooo....
somethign saw fit to ice over our entire town bleh!
stupid ice..
but im glad i dont live where it snows.. thannnk god for that one
Army vet 02-08
