Old 01-24-2009, 05:02 PM   #1
Andy4639
Old member
Andy4639's Avatar
Changed oil ...
and I found this. Top hose is leaking at the neck. It's not the hose leaking but the metal neck of the radiator itself. Anyone seen this before and know a fix for it.
Can I take it out and have it fixed?
I don't like stop leak stuff so don't even say it!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2009, 05:06 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Changed oil ...
A radiator shop can braze that for you.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-24-2009, 05:07 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: Changed oil ...
yup, bet they can braze it for cheaps
leddzepp is offline   Reply With Quote
Old 01-24-2009, 05:23 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Changed oil ...
10 to 20 dollars at any rad shop
Old 01-24-2009, 05:37 PM   #5
72armyswbtruck
72armyswbtruck's Avatar
Re: Changed oil ...
Too slow on the draw.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-24-2009, 06:09 PM   #6
Andy4639
Old member
Andy4639's Avatar
Re: Changed oil ...
I wonder if they could do it in the truck without having to empty all the coolant out?
Old 01-24-2009, 06:22 PM   #7
orangek5
orangek5's Avatar
Re: Changed oil ...
It would prolly be a good idea to go ahead and remove it and have it boiled out at the same time they braze the tube. I had mine boiled out and it only cost 40$ "ounce of prevention" bla bla bla.
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 01-24-2009, 06:35 PM   #8
Andy4639
Old member
Andy4639's Avatar
Re: Changed oil ...
The rad. itself is only a couple of years old. I bought a brand new one. I wouldn't think it needs rodding yet. Thanks though.
That's why I wonder if they could do it inside the truck.
Old 01-24-2009, 06:49 PM   #9
El Jay
Gone to greener pastures
Re: Changed oil ...
I'd imagine the radiator would have to be pretty "dry" to braze it.
If you want to save the coolant & have them try to repair it in place; you could drain your coolant & save it.
Fill your cooling system with water & have the radiator shop dump the water & make the repair.
Refill it with water there.
When you get home, dump the water & put your coolant back in.
For the cost of antifreeze, I'd just put in new though.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-24-2009, 06:49 PM   #10
Longhorn Man
Re: Changed oil ...
they can't do it properly in the truck. The coolant will keep the tank from heating up when they try to braze/solder it.
Pull it out and hand carry it in.
Old 01-24-2009, 06:59 PM   #11
Kayotic
Kayotic's Avatar
Re: Changed oil ...
I agree with everybody else. Since it is a cheap fix, I would go through the trouble and remove it, then they can also test it properly.
Straight forward task once you have the shroud out of the way if you have one.
I say pull it.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-24-2009, 07:24 PM   #12
Longhorn Man
Re: Changed oil ...
thats another good point, they won't be able to test it for leaks installed.
they'll probably refuse to do it in the truck plain and simple.
Old 01-24-2009, 07:34 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Re: Changed oil ...
After it is fixed, use distilled water instead of tap water.
Old 01-24-2009, 08:24 PM   #14
Andy4639
Old member
Andy4639's Avatar
Re: Changed oil ...
Well I guess next week it's going to the shop to have it fixed.
