Old 01-24-2009, 07:34 PM   #1
pete29
engine tuning help PLEASE
Good news. I got my 72 chevy original 350 with original 4 barrel rochester quad. running. It has an hei distributor on it now. i stuck a timin light on it. When i move the distrubutor more clockwise to get the mark lined up better the engine starts running slower. Is this normal. Then when i had it all lined up it was runin decent, and i could shut it off and start it just fine a little while later. but then i let it set overnight and went to try start it but it wouldn't, so i turned the distributor counter-clockwise a little, the place where it was runnin faster, and then tried starting it and it started. So i left it there. and its idlelin pretty good, but when you push down the pedal it wants to die out and you have to let off then pump it again to get it goin faster. Any suggestions on what to do. Would it be a good idea to get a different carb for it. Whats a good one for this 350 engine. It does have bigger valves and cam.
pete29 is offline   Reply With Quote
Old 01-24-2009, 07:52 PM   #2
JimKshortstep4x4
Re: engine tuning help PLEASE
When you turn the distributor clockwise you are retarding the timing so the engine will run slower.
Counter clockwise will advance the timing.
What are you trying to set the timing to and do you have the vacuum advance disconnected?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-24-2009, 07:57 PM   #3
pete29
The vaccum hose is disconnected. This is the first time i've ever tried to time anything. I'm not sure what its suppose to be timed at but i was trying to get the mark lined up exactly with the slot on the tab. Good idea or not?
Old 01-24-2009, 08:37 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
what are we supposed to set our 350 motors for..ima be setting mine soon..but didnt know what to set it as mines a 350 also, thanks!
John
1999 Toyota Tacoma 4x4
Old 01-24-2009, 08:43 PM   #5
El Jay
Gone to greener pastures
About 4 degrees before, distributor vacuum line disconnected & plugged will put you in the ball park.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-24-2009, 09:04 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I would try setting the timing at 10 degrees BTDC and then try driving it with that setting. You should get pretty decent acceleration and performance with that setting.
piecesparts is offline   Reply With Quote
Old 01-24-2009, 09:49 PM   #7
pete29
when u say 10 degrees btdc. does that mean before the mark 10 degrees, or what does it mean.
Old 01-25-2009, 11:19 AM   #8
piecesparts
Yes sir, that is just what I mean. If you have your timing marks cleaned up to a point where you can read them easily, you will note that there is a "0" and then there are marks without numbers and then there is a 10. That is where I would start on the timing. Many GM engines call for a 4 degree or 6 degree timing, I have found that is good, but little better response is found when you set you timng a little advanced. I used to run my engines at 10 to 12 degrees "Initial timing setting" and then when the vacuum hose was connected, the distributor would provide for whatever centrifugal advance from there.
I now use a timing light with a Built-in "advance" dial-in feature and I adjust my distributors for a TOTAL advance number that is about 35 degrees. This seems to work well for the engines that I have built and they run quite well on the street.
