Do I need new springs?
the front springs hit on the frame all the time, what can I do to stop that or is it just normal?
Re: Do I need new springs?
My trucks all have a bracket behind the front shackle that prevents it from hitting the frame. Sorry, I don't have a picture.
Your springs look ok to me. They should be replace if they bow upwards. Stock springs are flat. Also, the bracket is only on the driver side. john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 01-24-2009 at 08:59 PM. |
can someone post a picture of what the back bracket should look like?
Here is a picture of the whole leaf spring
I think that this a a common problem. Offroad desing sells a shackle that is not much longer than stock but a lot more heavy duty that should help with the problem. One other thing to think about. Did you buy the springs or were they on the truck. You might want to check the part number they might be for a 73-87 truck instead of 67-72. The springs for the 73-87 are longer this could casue your problem.
#6 | |
In House Collision Technician
I was watching a show on tv of a muscle car built up and they were slightly towars the front but this was a car. Pictures would help me alot guys...
Guess I can't see it, but where is it hitting the frame?? You want the shackle angled back alittle bit, it helps in flexing and a better ride. I would get longer shackles, only need 1/2-1" tops. Can go to a metal shop and get some peices probly for free, just cut them to length and drill a 7/16" hole.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Its hitting on the red, I bought the truck with the lift already. Could it be the shocks?
Post Whore
![]() Join Date: Feb 2000
No. You don't want the shocks to be the limiting the spring movement or you'll break your shocks. Your springs must be flexing a good amount to be having contact where you have indicated. I would consider your shackle angle to be fine.
Hopefully the guys who know a bit more than I about suspensions will have a good recomendation for you. Slightly longer shackles will probably be the recommendation.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Big Boys With Big Toys
Wrong springs or longer shackles
