01-25-2009, 12:29 AM | #1 |
Finally found a 292
I've been searching for a 292 for my Panel for quite a while, and I finally found one last week. It's a basket case, but it don't seem to have any cracks in the usual places.
The bores mike out at .030 over, but I can't find anythind on the pistons that say they are oversized-but I havn't looked real close. The crank has .020 bearings. So I have a couple questions: How much can you grind the crank? And how muck can it be bored? One thing I thought was clever, the guy I bought it from had several motors in his shop, and they all were standing up on these: Some kind of furniture leg or something, with a nylon pad and 3/8 threads so it can screw right into the bell housing bolt holes. Makes it a breeze to slide it around on a shop floor without scratching up the floor. I need to get this block down to the machine shop and have it inspected before I make too many plans, but the general plan is to have a supercharged 292 in my Panel when it is complete.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
01-25-2009, 01:23 AM | #2 |
Resident of Here
Re: Finally found a 292
They have been bored .0100 over to fit 307 pistons.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-25-2009, 04:17 AM | #3 |
Saving 1 truck at a time!
I've got a great running 292 for sale...the truck comes with it for only $400!!!! You could have driven it home...LOL! It has never been apart and starts every time. New starter and new tires too!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
01-25-2009, 04:55 AM | #4 |
If it's indicating .030 over, it's most likely been rebuilt once. No problem as long as the magnaflux test shows it's all OK. Next stop is .040-over or even .060-over. There's still a lot of meat on those old blocks.
STD=292 .030=296 .040=298(?) .060=301 What vintage is your engine? You can tell by the casting numbers on the drivers side and also the stamped numbers aft of the distributer hole.
01-26-2009, 11:09 PM | #5 | |
We could even have a conversation about the TH400 that goes with that 327 and that posi in lamont. J/K... I'm currently not blue, so I can't be making any offers like that. I must have not looked close enough-the numbers on mine seem to give a fairly broad range of years, like '62 to '70 something. I'll know more after it's cleaned up better.
01-26-2009, 11:35 PM | #6 | |
FarmBoy.
Well, the 292 has the same bore as a 250 and 230...which is the same bore as a 283 and 307...3.875.
the only issue is the wrist pin height in relation to the rest of the piston. Which is why the 230 and 283 uses the same piston, and the 250 and 307 use the same piston. Sadly, the 292 is pretty SOL when it comes to off the shelf pistons. That aside, they can take a .060 over bore safely, with .100 to .125 if the block is checked. To my knowledge anyway...someone can correct me if i'm wrong. Other than that, I love the idea of a 'charged 292. Forged pistons with a 8.5-8.75 ratio should be just what the doctor ordered for some boost... -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
01-27-2009, 12:09 AM | #7 |
someday it will be done!
Back when my 66 step was my dd,I was in the middle of a road trip and happened across a fella at a gas station that was filling up his beat up ol 64 fleet.He grinned ear to ear when I pulled in beside him and we got to talking of course.I gave him a quick run down of my beater(nothing special to anyone but me) and when I was done,he led me around to the front of his hauler and popped the hood.There it was,a supercharged 250.Hadn't heard of it before or since....till now.
Very cool plan can't wait to see the pics!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-27-2009, 01:01 AM | #8 |
the 292 engines are hard too find and parts for the 292 engines too
01-28-2009, 10:56 AM | #9 | |
FarmBoy.
292's aren't all that hard to find...I have 3 of them...
and most parts interchange with the smaller displacements. -Sam.
