01-25-2009, 10:17 AM | #1 |
72 GMC
Vacuum advance question
Hey
How can I tell if my vacuum advance is working BEFORE I put the distributor back in the truck ? I hooked it up to another vehicle, but I don't know how much vacuum I need to pull before this thing should move. Any help would be appreciated. Thanks guys. |
01-25-2009, 10:28 AM | #2 |
Active Member
Re: Vacuum advance question
If you're referring to the movement created by vacuum, it should move by just sucking on the end with your mouth. I use a short piece of hose if it's still on the engine.. Doesn't take a log of vacuum to move it.
If it doesn't move then it's defective. |
01-25-2009, 10:34 AM | #3 |
72 GMC
it doesn't move.
glad i asked before re-assembly thanks for the help |
