What if?
small hump?
anyone have any pics of a small hump vs a large hump?
i have a 70 c10 that had a 6cyl three speed on the column. i have since converted it over to a 327/350. i have heard the term small hump and large hump but havnt paid much attention to the trucks i have owned to really know what i have. reason i am asking is that i plan on getting carpet for my truck after christmas and need to know what to look for to determine between the two humps. i am betting that i have a small hump due to it had the saginaw three speed in it. |
From what I have read. The large hump was in 4x4 trucks and also trucks with turbo 400 trannys. I found this out when I was installing rubber floor mat in my 3/4 ton truck. Good luck with this info.
'72 GMC custom camper 350/350 |
Check out Wes's website at http://classicheartbeat.com/index.html
Check page 2 under interiors, and there's a tech tip to explain the difference between low hump and high hump. Hope this helps? ![]() ![]()
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
high humps were used in trucks that were originally 4x4 or originally came with a floor shift transmission. low humps were trucks that had column shift transmission.
What if?
cool thanks guys,i guess i have a low hump then.
MOST big block trucks with autos were high humps as well, but most had TH400s. One exception to this might be 1/2 ton big blocks, especially in Suburbans.
Active Member
Here's a pic of a low hump in my 69 C/10 turbo 400 small block.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
My other Love
Hmm I always thought I had a small hump. Now that I see that pic I guess i have a big hump. I have a th400 in my 69. I always thought the large hump cabs had the center hub that was bolted to the cab?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
![]() ![]() Join Date: Jul 2002
I have heard, but never seen one myself, that high humps bolt in, while the low humps, like the picture shows, are integral with the floorboard.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Here is a link to where I have the explenation in my helpfull tips section of our website. Pictures too!!
http://www.classicheartbeat.com/high_low_humps.htm WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
So Many Ideas, So Little Money
yeah high humps bolt in, lows are part of he floor, lows are something like 3-4 inches tall tops
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
What if?
well that helped a ton,thanks!! i now know i have a low hump.
#13 |
its all about the +6 inches
It has been documented that 4 speeds, 4X4's, and big block trucks had high humps....but I suspect that GMC trucks with the V-6 had them too. I know mine (with a TH400) has a high hump....however, the one ton that had a 350/TH400 has a small hump.
Here is the high hump bolt in deal in my GMC. |
#14 |
Hootis is as Hootis does...
If you have a low hump - (327 motor, glide) and are going to convert to a Big Block and Turbo 400, do you have to go to the high hump, or will it fit with the lowhump?
#15 |
most likely....they did at the factory.
#16 |
So, is the low hump welded to the floor. I have a project going that has a HH now but it originally was a LH. The HH has a cutout for what looks like a 4 sp. and I will need to patch it to cover the hole. It is back with the 350/350 setup so I no longer need the HH. Instead of patching the HH would I be able to weld in a LH if I can find one?
#17 |
if you find one outta a junked truck you can weld it back in yes
#18 |
So can someone confirm.....
You can fit a big block with a TH 400 in a pickup that has a small hump? No clearance problems? Longhornmail may have answered this. But it was unclear whos question he was answering. Thanks, Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
#19 |
can a high hump cab be converted to a low hump relatively easy? i prefer the low hump better but the new cab im purchasing is a high hump
can a low hump section be purchased from anywhere or would i have to go cut one out a junk yard cab? |
#20 |
darren, I was refering to your Q...but it is mostly speculation.
I know it is starting to look like I'll have hump clearnace trouble on my caddy swap...but that don't really cound. |
#21 |
We have put big blocks and t-400's in low humps without any real problems, on one we had to cut the firewall to floor seam flush in the hump and weld it back together, could have just hammered it flat and it would have worked.
Rest in Peace Ed. Thanks for all the good times. |
