tranny does not shift
ok so on friday the truck ran fine and we changed the lift on the truck because it was lifted using blocks so after we changed leaf springs and put it all back together now it does not shift into gear and i checked trans fluid its fine and i also checked the vacum line from the back of the motor to the tranny and that is also fine is there anything i may have done while changing the springs that may have caused this
LIFTED OR LOWERED EITHER WAY STOCK SUCKS 75 Chevy blazer 86 trx 250R 1990 Ford Ranger 2wd prerunner project |
One shot, one kill.
Re: tranny does not shift
Lifted, about all you could have done is, in some way damaged the shift linkage either internally or externally. Disconnect the shift linkage at the trans and have someone you trust start her up and hold the brake. Shift the trans right at the case and see if it applies. If it does, the linkage is damaged outside the trans. If it doesn't, the linkage inside the trans is damaged. let us know. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
