Old 01-26-2009, 12:00 AM   #1
70onB.A.D.'s
70onB.A.D.'s's Avatar
Frame Mount Battery Options
Hey guys anybody every mounted a battery on the rear frame rails. If so how did you go about doing it? Thanks
70onB.A.D.'s is offline   Reply With Quote
Old 01-26-2009, 01:58 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Frame Mount Battery Options
Classic Performance Products has a great stainless steel dropout battery box that mounts on the frame.
Tom Vogel is offline   Reply With Quote
Old 01-26-2009, 01:46 PM   #3
70onB.A.D.'s
Thanks for the help going to go check it out.
Old 01-28-2009, 01:57 PM   #4
chris71
chris71's Avatar
I have a No-limit drop out stainless box on my 55, it should be able to work on any car or truck with a flat side frame, i mounted mine under the cab
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 01-29-2009, 10:44 PM   #5
70onB.A.D.'s
chris 71 where did you get the drop out box?
Old 01-30-2009, 07:13 AM   #6
chris71
chris71's Avatar
No-limit engineering, the box is not polished, it says it was made for series 74 bateries, i think for the optima dry cell batteries, but i have a napa battery in there right now. you will most likely need a side post battery. fyi, there is no "hold down mechanism" for the battery, you can drill a hole on each side and use the J bolts with some flat stock on top, or other technique. what this box has, is a flange that folds over the battery, I actually folded the flange back to put the battery in then bent it back down. sort of a PITA.
http://nolimit.net/prodinfo.asp?number=BT%2D300
Old 01-30-2009, 07:21 AM   #7
chris71
chris71's Avatar
just checked out the one from CPP, its cheaper and has a hold down function too.
http://www.classicperform.com/Store/...cks/BDBS24.htm
http://www.classicperform.com/tech_a...attery-Box.htm
Old 01-30-2009, 02:15 PM   #8
70onB.A.D.'s
cool, yeah after looking at the hold down function on the cpp one plus the drop out feature is cool to so I will prob be going with that one.
