It followed me home?
How do I gain another 1" in the rear?
I have a flip kit in the back of my 77 and for some reason it brought the back end down around 8" so I added a shorter shackle to bring it up a little, but I would still like it about 1" taller.
Actually I dont mind how it looks but I want a little bit of rake so the front sits too low. So anybody have an idea how to bring up the rear a bit?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: How do I gain another 1" in the rear?
delete
You might be able to remove a leaf, but that's sh ty answer.(re-thint that won't work, would it? Your axle is already sitting on the main leaf w/eye's on each end. You may be stuck on that one.
You may have to move the hangers on the frame. I can't think of other options. double sh ty. Last edited by Kayotic; 01-26-2009 at 04:36 PM. |
#4 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
go get some air shocks, they are about 75 a pair and air em up...that raised my 05 up a least an inch.
67-72 parts collector,…
![]() Join Date: Nov 2002
cochino12,... the only answer I have will work,... but it won't be fun to do.
You need to change out the rear leaf spring hanger with one from a 4x4 blazer. I saw this done in a magazine years ago. They had the same problem. Used a flip kit and it sat TOO low. They swapped the 2wd hangers for a set of longer 4x4 hangers. Seems like it raised it another inch+. The big pain is the tank being in the way,... and the hangers are riveted on. My '82 2wd blazer that I use to have, had a flip kit also. I solve the "lowness" by unflipping it, and using 4" lowered leaf springs and long shackles. If I had it to do over I would have just gone the "4x4 hanger" route. Alot cheaper and the long shackle doesn't get in the way of the fuel fill hose.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-26-2009 at 07:09 PM. |
I too had same problem ,I just got a bigger tire in the back
#8 | |
I think that is what I'm going to end up doing, I just dont have the $$ to ditch the rally wheels right now. I was hoping there would be a simple fix but...
have you thought about dropping the front some more to achieve your desired rake?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht Last edited by hotrodhomi; 01-27-2009 at 06:30 PM. |
Yep,... just the rear 4x4 hanger (back by the bumper) should do it.
#11 | |
I think what I'll do temporarily is add a taller tire to the back and then I can add spring 1" taller to the front. Later this summer I'll order a set of bigger wheels and tires and then hopefully I wont drag the control arms over extremely small bumps ha ha
What about the inner fenders?
How far are you away from them now?
#13 |
I'm glad you are paying attention, I didnt even think about that ha ha. They are about 3-4" away right now, do most people pull them out, cut holes in the top, trailer fenders ?
#14 |
#15 | ||
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
