Old 01-26-2009, 12:03 PM   #1
ScottH
ScottH's Avatar
FS: 72 350 engine
I have a bunch of parts I've collected over the years to rebuild a 350 4 bolt main engine I took out of a 72 C10 a while ago. The block is bare but very rebuildable. I have a rotating assembly with flat top pistons, recond rods, good crank, assembly was balanced (used but in great shape). I can include the following new parts: ring set, bearing set, push rods, freeze out plugs, head bolts, timing gear and chain (double). About all you would need is a gasket kit, cam kit, and oil pump. Also my son has a set of 305 heads that have been shaved and slightly ported with 202 valves in them, VERY low miles. Asking $300 for the block and new parts, and I can check with my son on the heads if anyone is interested.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 01-26-2009, 01:09 PM   #2
finch
finch's Avatar
Re: FS: 72 350 engine
stock bore and stroke?
Andy...
'70 C/10 Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=298553
'71 K/20 Frame-off resto, SOLD!!!
http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12
'05 Silverado Z-71, CC SB, Daily Driver
finch is offline   Reply With Quote
Old 01-26-2009, 01:16 PM   #3
ScottH
ScottH's Avatar
Yupper
Old 01-26-2009, 10:58 PM   #4
ScottH
ScottH's Avatar
ttt
Old 01-27-2009, 10:12 PM   #5
finch
finch's Avatar
dang, I need .030 over pistons. bump for a great price!
Andy...
Old 01-28-2009, 01:06 PM   #6
ScottH
ScottH's Avatar
Price dropped to $250
Old 01-29-2009, 11:10 AM   #7
ScottH
ScottH's Avatar
ttt
Old 01-29-2009, 03:01 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
ugh!!!...that is an awesome price Scott!!!....Wish I was closer to you!!!...I've always wanted to rebuild an engine...which I don't have the slightest knowledge on right now!...What else would be need to get it to be a running engine?...manifold, carb, cam...etc?? Thanks
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-29-2009, 03:04 PM   #9
jaros44sr
jaros44sr's Avatar
Dang Scott, that is a great price...and you're close by.Tempting, are you sure the numbers match '72
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-29-2009, 03:31 PM   #10
ScottH
ScottH's Avatar
gcburdic, I think that is about all u would need other than some block work (honed, new cam bearings, etc.).
jaros, I pulled the engine myself when it was complete and running, my son drove the 72 C10 for about a year. We parted it out which is why it was pulled. BUT just so I'm not just assuming it was original, I'll pull the numbers over the weekend and post them.
Scott
Old 01-29-2009, 03:54 PM   #11
jaros44sr
jaros44sr's Avatar
Scott
No rush, I'm second in line, I think. Would be nice to have correct date numbers
SAFETY FIRST
AS usual, off topic
Jim
Old 02-03-2009, 11:49 PM   #12
ScottH
ScottH's Avatar
Sorry guys, couldn't get to the block over the weekend but should be able to this coming weekend.
I'll keep u posted.
Scott
