Old 01-26-2009, 12:32 PM   #1
roofing458
1966 bench seat switch-
Who has updated the old bench seat from a 66 C10 & installed a later model 40-20-40 seat power .i did a search i found a 67 & up post .Just need some info on what donor truck was used & what issues , ideas you guys have
roofing458 is offline   Reply With Quote
Old 01-26-2009, 01:09 PM   #2
joe231
joe231's Avatar
Re: 1966 bench seat switch-
nice truck....
billydonn put newer seats in his truck.....let me see if I can find a pic
CHEVY ONLY
Old 01-26-2009, 02:17 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Here's a consensus form one of the other boards...
<- this is between totally different posts on another variation of the seat swap question
-- <- this is between posts that are similiar or where taken from the same thread. Such as a question and answer...
All of these tips were found here in chevytalk 60-66 trucks forum, questions and answers from the many, many posters, credit given for question and answer.
Sometimes I took different, yet similiar answers from the same people from as many as 3 or 5 different posts and put them together.
Anyway, it's long and rough, but maybe it'll help some folks...
-W
-----------begin--------- --------
My 92 Silverado bench fit fine witih the tank still in.
It was almost touching but I drove it before the tank removal without wishing I could move it back anymore.
Barn - chevytalk
I have a 60/40 early 90's in mine and it's very comfortable. I used the seats' mounting brackets and only needed some new
mounting holes.
dvalentine - chevytalk
i just bought a set from a 01 chevy a couple weeks ago for my 60 havnt mounted them down yet.yes the center section needs
mods to the mount brakets.they do put you a little closer to the dash.a smaller steering wheel will help.they are perfect for
my size at 5'10".im also in the process of removing the in cab tank,that will also help on mounting the center section.
have a set of 01 seats in my 60,at 5'10" its great with stock diameter steering wheel.guys a little over 6' may be a little
cramped. looks very nice,but need mods to the floor mounts for the center section that i havent gotten too yet
57wagon - chevytalk
"what year full size 90's chevy trucks have the integrated seat belts? - Woogeroo"
'99s to current '05s have them
61StepSide - chevytalk
I have a 60/40 out of a '96 GMC. It doesn't have the intergrated seat belts but it does have a hole with a plastic bezel for
the middle seat belt.
chevytrucknut - chevy talk
I bought seats made by Steel Horse for '88 to whatever and they fit perfectly in my '66. I had to cut a piece of the mounting
bracket off and drill holes in the floor of the cab to fit. The width is perfect
persh - chevytalk
hey guys what trucks/vans/cars make good donors for a nice custom look 60/40 or 40/20/40 for a 1966 truck thanks
ZZ430trk
90's Dodge truck seats, 1994 and up that is.
Chevy1966pu
I saw a 66 at a car show that had leather buckets from a 96 z71 that look really hot. They even used the center console.
Krzcwby
I put 89 F--d Lariot bench seat in mine.It has a nice pull down arm rest built in.Mine is red to match the interior.The seat
is soft and comfy.
chevytrucknut61
hey trucknut, how did the bolt holes line up for that F**d seat?
jtruck
I had to build stands to bolt on the floor to mount it. Of course the hole didn't match but the front mount curves down like
the floor pan.
chevytrucknut61
I got a becnh out of the mid 70's chevy half ton. It is wicked comfy and bolted right on in...
lowrolledc-10
bucket seats:
hey guys i have a quick question i have a 1966 truck with the original bench seat i want to upgrade the seat to a nice
cruisable bucket seats or captian's chairs, where to find them?; which cars/trucks/vans make good donors? what did you do to
mount them? any tips will help thanx
ZZ430trk
I found a set of buckets out of a 2000 Chevy pickup. I was lucky, the guy was going to put them in a '68 chevy p/u but ended
up wrecking it. I found mine on craigslist.org. They are very comfy, I had do to some fabricating to make them fit, and the
plus is they have the shoulder belts built in. Others have used split bench. If you do a search under "bench seat" or "bucket
seat" you will find a ton of info.
Knuckle_bustin'
I used seats out of a Chevy mini van in my panel. The height is great. And their very comfortable bucket style seats with
armrest.
krylonkid
I've been wondering what was the front seat in the suburbans? I know on the panels they were bucket seats, was the burbs the
same?
Chevyboy62
The burbs had a 60/40 bench. The passenger side was the 40. It flipped forward, seat bottom and all, to allow access to the
rear. AND, that seat was also in panel trucks.
dvalentine
I'd say more of a 70/30. Just ask my wife on a long trip!
gmc63burban
'94-'99 60/40 chevy seat
Do any of you have these, and how hard were they to adapt to your cab? Right now I still have an inside gas tank, But I plan
on moving it. It might not be before I get the seats though. I have a friend with a '96 Z-71 who is giving me his seats.
SilverStreak
I have a '96 60/40 bench. It works fine with the tank. The hardest thing to mounting the seat is the 4 extra holes and making
a spacer for thebrackets to sit on. The floor hump is higher on the newer trucks so the brackets need spacer under them. I just stacked fender washers. Works great.
chevytrucknut
Mine is from a '92 Silverado. (Mounting sounds different than Nut's '96 though.)
Drilled two holes. Tank is still in the cab.
Barn
I just snagged a set of these on ebay. I had heard they would fit so just decided to get them. I have the buckets in my '99
Tahoe and they're so comfortable I wanted the same for the '64. I got the 60/40 bench with drivers side power. Not too bad.
swierker
About those 60/40 seats you guys are installing
Are they with the tank inside the cab or out. Right now my tank is still inside but I want a 60/40
slingblade
i got bucket/bench from a 68(i don't know if it's similar to what you want,) but i got the tank inside and its not too bad
1960stepside
I put a 40/60 split in from a '93 Chev pickup and left the original tank with no problems at all. Just needed a couple of
extra bolts for the other tracks. It has been the best update so far in my truxk. Just like they were made for the earlier
cabs.
GMDad
1965 Chev Pick-up 292 5 spd <- from signature line
if you'll look at where your seat hits the back of the cab,you'll see that the top of the tank is way lower.
zenish
Burb seats:
FYI, there is 2 mounting systems on the burb seats. One is fixed and locks into a hole in the floor. The other system is
movable (like my burb) and attatch to 2 tracks in the floor.
gmc63burban
The '88 and newer GM truck seats are a near bolt-in. Two holes line right up. '92 and newer have built-in headrests.
Chevy1966pu
I used a mid 70's chevy bench and it went in good....the only problem i found (beside drilling the two back holes) was that
is sat a little low for my 6-3" frame, so I sat it on two 2"x2" steel tubes.
I put in a 1977 blazer bench seat and got the upholster kit from LMC Truck. Recovering the seat was probably the single
easiest part of the restoration process.
chadman03
Here are some minivan seats I got cheap. They have storage drawers underneath. They should leave alot of room in the cab.
Shouldn't be too hard to install. Maybe some custom brackets and drilling nothing too hard. Maybe only some shims in the
front or back to get it level. They need upholstery but that should be inexpensive and I'll be able to select whatever color
or pattern that suits me.
tkdtkd
I installed a '92 Chev full size pickup cloth 40/60 split and it went in real easy and it makes one major difference in the
comfort unit of these trucks. Definetly recommend trying to find one.
I used the '92 tracks and drilled the other holes. I like the 60/40 split as I have a 5 spd in mine and the wife is a little
shorter in the legs when she is driving but no problem with the split seat. Gives it the new truck feeling when you are
driving it.
I put a '93 split 60/40 in my 1965 and it went right in with just drilling the extra couple holes for the extra tracks. Works
unbelievably well, especially with the floor shift. It has to be one of the easiest and best modifications for our truck.
GMdad
I am with GMDad on this one. I only know of the '88-'98 seats fitting easily. Two bolts line up, and only the other two need
drilling. I will get a seat from these years. Also, I think it is '92 and up with the headrest upgrade.
Chevy1966pu
The guy I bought my truck from said the seat (and the frame, I think) came out of an '83. All I know is it looks factory.
The frame rails on my seat are 5 1/2" from floor to bottom of the seat. The seat is 8" thick and there is 6 1/2" from the
seat to the bottom of my stock steering wheel.
66 Longbed Stepside
longbedder
what kind of brackets were used to install 94 model 60/40 seat in 1963 chev?
ironbutt_lcmc
I got a '64 with a '92 bench and didn't need to do anything but drill the two rear holes. Don't know if that helps ya or not!
Barn
Do these 88's and up seats just bold in the existing holes?
raven316
Front holes line up,rear must be drilled.
64fleetside
________________________________________________________________
And here is a kind of summary.
99-05 tahoe, suburban, yukon, silverado seats work great, and they also have built in seatbelts for us pre 66' people. In street trucks mag they have project old school, and they did a seat search for 60-66 trucks, 99-05 chevy seats placed #1, and 88-98 chevy seats second.
ol Curt is offline   Reply With Quote
Old 01-26-2009, 02:45 PM   #4
joe231
joe231's Avatar
holy crap curt, that is a hella long post
here ya go
http://67-72chevytrucks.com/vboard/s...03&postcount=7
CHEVY ONLY
Old 01-26-2009, 04:06 PM   #5
roofing458
Thanks so much for your time & effort on this post.Now i know what im looking for .Your da best Thanks Kevin
Old 01-26-2009, 04:08 PM   #6
roofing458
jOE 321 .yours looks great .what was that out of ?
Old 01-26-2009, 04:10 PM   #7
joe231
joe231's Avatar
click the link...these are another members (Billydonn)
it tells what they are from in the link I posted
CHEVY ONLY
Old 01-26-2009, 04:50 PM   #8
502tripower
502tripower's Avatar
Here is mine 98' Silverado Seat. Front mount lined up perfect. I made up son 1X3/8" Flat bar drilled and tapped mounted the rear of the seat and plug welded. This is how the factory mounts were done. Very easy.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-26-2009, 04:59 PM   #9
joe231
joe231's Avatar
how is the leg room with that seat 502?
CHEVY ONLY
Old 01-26-2009, 05:03 PM   #10
502tripower
Joe, It is very good. Notice how far forward I set the mount so I could adjust the seat as far back and still use the tilt on the backrest. I would say it has about the same leg room as my 2002 2500HD regular cab.
98' FXD
2002 2500HD
Old 01-26-2009, 05:05 PM   #11
1963chevyshort
New Member
1963chevyshort's Avatar
yeah and those seats look very confortable.
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 01-26-2009, 05:06 PM   #12
joe231
joe231's Avatar
cool!
so I see the hole there, you gonna run the silverado shoulder belts also?
CHEVY ONLY
Old 01-26-2009, 05:13 PM   #13
502tripower
Originally Posted by joe231 View Post
cool!
Yes, When I purchased the seat new in 98 I also bought the matching belts. My original 63' cab was a BBW and the 62' cab was a SBW. I took the BBW liner out of the 63' and put it into the 62' Cab and made the sholder harness bosses at the same time. The retractors mount just behind the door pillar using the same manner as the seat and shoulder harness bosses and look factory.
98' FXD
2002 2500HD
Old 01-26-2009, 05:15 PM   #14
joe231
joe231's Avatar
cool, that is pretty much exactly what I have been thinking about using
CHEVY ONLY
Old 01-26-2009, 06:59 PM   #15
ol Curt
Junior Member
ol Curt's Avatar
here ya go
I figured I could give him the link, or just the straight poop and nothing but the poop, so help me.........hey, they did use a bible for that second swearing in didn't they??
Old 06-05-2011, 08:35 AM   #16
RoyL
RoyL's Avatar
From the Classic Truck Article on Seats Swaps for a '64 Chevy. http://1.bp.blogspot.com/_RU3AEuCB50...+seat+swap.jpg Thanks to Mr. Natural . . .
I have seats from a 2003 Silverado, going into a 65 Suburban. The article says you have to modify the center seat mounting. Anybody done this to clarify what needs to be done? I read elsewhere that you need to move the center holes 4 inches back to mount with the seats inner tracks??
My trial fit looks like the whole 3 piece seat assembly, as is, is too wide for the Suburban. The outer seat tracks (nearest the doors) don't sit on the flat part in the floor, or too close to mount securely . . . Will post some pics later.
Thx,
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 06-07-2011, 04:46 AM   #17
RoyL
RoyL's Avatar
Thx,
Roy
The link to the full seat article and some pics:
Article is from Aug 2004.
http://chevtruckseatswap.blogspot.co...blog-post.html
Driver side:
passenger side, might be able to shift driver's side closer to the edge. Still not clear what mod I need to do for the center piece?? Article says they had to trim the center console brackets slightly to fit over the hump. Another post I saw said the floor mounts on the center section have to be relocated 4 in further back to mount in the same holes as the seats inner tracks.
Thx for any insight,
Roy
1965 Suburban
Old 06-07-2011, 11:16 AM   #18
jimmydean
jimmydean's Avatar
I went with something a little more plush.
the wiring was a nightmare on these, but they work (minus heat and cool).
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-09-2011, 06:39 PM   #19
Woogeroo
The 60-66 seat swap thread at CT... where ol Curt got that long post, that I researched and wrote.
It has since had some more information added to it, along with pics and links.
I only add it in here, in case people stumble in here in the future while doing a search.
-W
UPDATE / EDIT : the 60-66 FAQ Index is maintained as a sticky at the top of the 60-66 Message Board. There is an entire section on Seats. Maybe one of those threads will come in handy for you.
Woogeroo is offline   Reply With Quote
Old 06-10-2011, 12:36 AM   #20
RoyL
RoyL's Avatar
Very nice looking seats! What year did they come out of? When did they start putting side airbags in the seats?
Roy
1965 Suburban
Old 06-10-2011, 12:26 PM   #21
jimmydean
jimmydean's Avatar
Roy
The Caddy seats are out of a 2007 DTS with cashmere interior, the center is 2010, I think. The center I found on ebay, guy had a stack of them pulled out of brand new fleet trucks.
My doors, kick panels, center console, and rear speaker rack are in matching vinyl to match the seat leather. The center is vinyl and doesn't match perfect, but it's very close in person.
The drivers seat bag was blown, so I got the seats for $250 for the pair from LKQ. Just rolled the bag up and shut the door.
The '05 and earlier have shoulder belts. But like the silverados, the belt is tied to the bag and if it blows, the belt locks in place. I didn't want to mess with the shoulder belts.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-10-2011, 01:03 PM   #22
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I like the Silverado setup!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-10-2011, 01:29 PM   #23
jimmydean
jimmydean's Avatar
The newer (2008?+) body style is even better, not as "thick" but can be spendy.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-10-2011, 08:37 AM   #24
RoyL
RoyL's Avatar
jimmy,
Since you mentioned LKQ, I gave them a call. They had a truck with power gray cloth 99-05 Silverado seats like I'm looking for, so sent my son to get them and they couldn't get them out of the truck . . . wasted trip to BHM. Still looking, the price was $125 each, so $250 for the pair, more reasonable than what I've seen on eBay for these!
btw, the drivers seat I have now is bent at the frame, didn't notice till the trial fit. Maybe that's why they don't want to fit??? If ya run across any, holler.
Thx,
Roy
1965 Suburban
Old 08-04-2011, 07:28 AM   #25
RoyL
RoyL's Avatar
Ok, update, got a good unbent seat, but they still won't sit flat on the floor, one side "falls off" the flat part of the floor. This is with the center console zipped tied where the mating holes are. I assume the Suburban cab floors the same as the truck?
The flat section of the floor measures from edge to edge at 54.5" before it ramps down to the door. The seat track bolt locations are ~54.75" [center to center] plus the seat track feet extend about a 0.5" more. If I take out the center console and place the seats to fit on the floor, the passenger seat rail is too close to the hump and a bracket/motor controller hits the fwd part of the hump when in the most fwd position . . . So it looks like I’ll have to do two things to make it work:
1. Trim the hump
2. Modify the center console brackets/feet
I thought these were bolt in . . .
Roy
1965 Suburban
