01-26-2009, 02:55 PM | #1 |
1966 gmc bagged burban front brakes
Does anybody have 60-66 that has been bagged? i am kinda having front brake line issues. The brake line is mounted on the upper bag support/ cross member close to the shock mount. The caliper side is at a 45 degree angle facing the front of the truck so this sorta makes an s shape and every time u raise and lower it the brake line goes up under the upper control arm. Does anyone have a fix for this problem?? It looks as if the brake line is in a bind and do not want to rub a hole in it over time. Please help
01-26-2009, 03:37 PM | #2 |
Junior Member
Re: 1966 gmc bagged burban front breaks
just bend a new brake line if it is in the way. Piece of cake man......
01-26-2009, 03:59 PM | #3 |
So just run a whole new brake line. Do i need to come in from a different angle??? Move the welded bracket???
