Old 01-26-2009, 04:04 PM   #1
the_goat
spring width
Are the springs from a 70 and later years the same width?Thanks
the_goat is offline   Reply With Quote
Old 01-26-2009, 07:29 PM   #2
the_goat
Re: spring width
I guess my real question is can I run a lift off of an 87 chevy 1/2 ton in my 70 blazer?
Old 01-26-2009, 08:11 PM   #3
skchevota
skchevota's Avatar
Re: spring width
The spring it self is the same width, but the bushing is wider in the late springs. The late springs are also a little bit longer. It has been a while, I dont remember by how much. You can use the spring mounts off of the late model truck and then use the late springs. If you are going to all that trouble, you may as well go with 52"s. Doityoursels4x4 has some pretty trick brakets to run the 52s.
skchevota is offline   Reply With Quote
Old 01-26-2009, 09:24 PM   #4
the_goat
Re: spring width
I was planning to go the 52 route. these springs were just so cheap and local for once.
Old 02-08-2009, 09:01 PM   #5
the_goat
Re: spring width
Could I run a set of lift blocks off of a later year? An 88?
