Old 01-26-2009, 09:40 PM   #1
CUSTOM DELUXE
CUSTOM DELUXE's Avatar
Center a/c diffuser for 64-66
I was wondering if any of you guys may have, or know someone that may have a center a/c diffuser. What I am wanting to do is have the old school look on the dash but put vintage air under the dash and route it out the center diffuser. Anybody got any direction on this? Know anybody that has tried this?
Thanks,
CUSTOM DELUXE
CUSTOM DELUXE is offline   Reply With Quote
Old 01-27-2009, 04:28 AM   #2
Blue666
Smile Re: Center a/c diffuser for 64-66
I am planning a similar upgrade for my 66 short fleetside. I was able to find the center vent on Ebay, but it is missing the retainer to keep the vertical vent in the unit. It otherwise needs stripped & rechromed/painted.
DVAL on the Chevy Truck Forum @ Classic Industries has done a real nice build in his 65 Suburban. He even has the part numbers from Vintage Air that you will need to construct the vent work behind the dash panel.
Good luck.
Blue666 is offline   Reply With Quote
Old 01-27-2009, 04:45 AM   #3
Blue666
Here's the scoop from DVAL
RE: Unique Center Vent
Funny you should ask this. I just wrote up something on how to adapt the center vent to aftermarket A/C for the new owner of my panel.
The procedure uses parts available from Vintage Air.
Directions for adapting Aftermarket Air Conditioning to
Factory A/C Center dash Cold Air Vent
I have prepared this truck to install an aftermarket under dash A/C Heater. The motor already has the necessary crank pulley, and I have included the Chevrolet Factory block-off plates needed to cover the holes in the firewall after the old heater box is removed. The factory block off plates will add a finished look to firewall after installation.
The 64 – 66 Chevrolet trucks offered a Factory Air option that included a center of dash cold air vent and moved the ash tray to an under dash location.
The following is a list of parts needed to connect the center of dash cold air vent to an aftermarket supplied air conditioner;
Vintage Air # 62415-VUE 2” to 2 ½” hose adapter ( 2 needed )
Vintage Air # 49592-VUI 2 ½” Y Connector
Vintage Air # 06250-VUE 2 ½” Duct Hose
Start by attaching the hose adapters ( # 62415-VUE ) to the back of the Chevrolet Truck factory center dash vent using super glue or another maximum bond adhesive of your choice.
Connect two short lengths of the 2 ½” hose ( # 06250-VUE ) to the Y connector ( # 49592-VUE)
Connect the Y Connector using the 2 ½” hose to the center vent output of the aftermarket under-dash air conditioning unit.
Two more dash vents will be needed on either side of the dash. There are a number of ways to go there using either under-dash mounted, or round or square shaped louvers that would be cut into the dash face.
I had planned on adapting the Chevrolet Factory a/c knobs to an aftermarket controller.
There are two vendors that I found,
Vintage Air (http://www.vintageair.com/) Sure Fit system and
Old Air Products ( http://www.oldairproducts.com/shop/index.php ) that manufacture under dash A/C heat systems for this truck. Of the two, Old Air products claims that their controller can use the factory knobs.
If retaining the factory knobs is something you wish, then Old Air would be a good choice. If that is not a priority, then either vendor would supply a kit that will go right in when installed by a competent installer.
DVal
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
Old 01-27-2009, 08:37 AM   #4
62 short step
62 short step's Avatar
That DVAL, he sure is very helpfull. Its a shame he sold that nice panel.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-28-2009, 08:01 PM   #5
TimE
Hey Y'all!!
TimE's Avatar
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-29-2009, 01:08 AM   #6
CUSTOM DELUXE
Thanks Blue666, that is a lot of information that I was wanting to know. Pretty much hits the nail on the head.. I tend to look at this forum for good advice. Y'all are awesome!!!
65 SWB FLEETSIDE CUSTOM CAB BBW
66 SWB FLEETSIDE - IN PIECES
67 SWB STEPSIDE- SOLD!!
72 SWB STEPSIDE- SOLD!!
03 Z71
04 TAHOE- WIFE'S
03 HD FATBOY 100TH ANNIVERSARY LUXURY BLUE PEARL
