4wd to 2wd conversion
I know it can be done, but how do you convert a 4wd truck to 2wd?
Is there a kit you can buy? Where? How much? and by the way how many gallons does the stock gas tank on a 87' c-10 hold? |
Re: 4wd to 2wd conversion
i think you should find a 2wd frame and swap your parts over. I'm not sure if anyone makes a kit to do the swap. I did 2wd to 4wd years ago and just switched frames.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
I have read a feww blogs on going from 2wd to 4wd so I would imagine it is the reverse LOL I plan on converting my 1 ton dually from 2wd to 4wd to bad you dont live closer we could just swap parts LOL.
huh ???
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Always a work in progress
You will need all the rear hangers. The shackle end, the leaf spring end, and the bump stops(unless you are lowering it). You will also need the whole front sub-frame wth the suspension and motor mounts that go from the frame to the x-member. also there is a x-member in front of the suspension x-member that you will need to get as well that holds the brake proportioning block. I just got all of the brackets for the rear yesterday from the pull-a-part for $28. You can also get the longer 2wd springs(some came with 56" vs the 52" on the 4wd) if you want a smoother ride. A cordless sawzall will be ur friend if you get parts from the pul-a-parts.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
