weighting my truck?
There is a truck stop by my house with scales.Would that work or should i use the one at the track.If the one at the truck stop will work.Should i park it at a certain place.
Re: weighting my truck?
you want to get a total weight and a front or rear weight so you will know what your front to rear ratios are.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Formerly ADHDCARGUY
The truck scales are in sections (to measure the weight on the different axles). Just be sure to put your trucks front end on one section and the rear on arother. That way, you'll have the the weight #s to work with!
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
Junior Member
The scales where I work are checked every three months and are good to 20 pounds +/- and they are just like the scales at a truck stop. I think you should be fine with the #'s you get there.
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 ![]() |
