Old 05-14-2002, 11:00 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Question Back-up lamp switch, will it work when 3-speed column is rigged for automatic???????
I am having a hard time finding an Automatic column for my 68.
So......we are just rigging up the already there 3-speed column, will the back-up lamps work if switched to the right place with the shifter??
If not,what can I do to make them work with the shifter.
OR....how do I add a switch for the back up lamps that will be neatly placed where the Choke knob was.
IN A TUX WITH A 68 BOWTIE.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 05-14-2002, 11:17 AM   #2
COBALT
COBALT's Avatar
Post
Well...the automatic columns have a hole where the neutral/safety switch (which controls backup lights) can use to connect it's actuating part to a metal tab on the part of the column that swivels inside when you shift. I'm surprised that the 3spd switch can't be adapted to what you need...
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-14-2002, 11:23 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Post
I don't think it'll work because the 3 speed column used an "H" pattern to shift with reverse at top left. The auto is sequential PRNDL2L1.
If your previous tranny was a 3 speed auto it should be easy to hook up a toggle switch to the wiring.
If you want to do it right, I have an auto column that is correct for a 68 with a th350 or th400 tranny.
What was your previous tranny? You may want to get an auto dash harness for the neatral safty switch wiring too. I may have that as well.
Jeff Jesseman
Cheyenne Parts Northeast
Franconia, NH
67 Chevy SWB Fleetside
70 GMC Burb 1/2 ton 2wd
72 Chevy Burb 3/4 ton 4x4
Parts bought and sold
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
