Old 01-27-2009, 09:08 AM   #1
cabinetman
Odometer won't turn
I had purchased a 1988 Chevy ¾ ton pickup that originally had an overdrive transmission I am not sure if it was called a 700R4 at that time or not. The previous owner changed the transmission to a TH350 because he was pulling a lot. The speedometer works fine but the odometer does not turn. Can anyone advise me as to why that may be? I have noticed a white plastic 4 contact pigtail connector hanging loose above the tranny and transfer case. Any help would be much appreciated.
cabinetman is offline   Reply With Quote
Old 01-27-2009, 11:00 PM   #2
cabinetman
Smile Re: Odometer won't turn
I don't feel so bad now, I usually can figure odd things like this out on my own but with no replies to this thread I guess I am not a total idiot.
Old 01-28-2009, 08:37 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I believe that the odometer still feeds off of the rotating assembly of the speedo, even in this truck. I may be wrong. So if the speedo turns, then the odometer should respond to it.
piecesparts is offline   Reply With Quote
Old 01-28-2009, 11:21 PM   #4
bwood
bwood's Avatar
The same thing happened on my 91 GMC Sonoma, the trip counter quit working one day. It didn't really bother me, but about a week later so did the odometer. THen I started to scratch my head. I pulled the cluster (also to replace some lights), I couldn't find anything serviceable, so I put it back in and it worked until I sold it. Don't know what I did other than replace the bad guage lamps.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 01-29-2009, 08:26 AM   #5
cabinetman
I had a replacement cluster from an '89 that I was going to replace it with but found out that from '88 to '89 they changed the electrical harness. So I've had mine out and back in, just didn't have your luck.
The more I think about it the more I believe it has to be electrical some how, some sort of a pickup sensor or something.
Well swap meet season starts in a little over a month, maybe I can find a replacement cluster. I'll just dink with the one I have for now and maybe get lucky.
Old 01-29-2009, 07:46 PM   #6
JohnO356
Your odometer and trip mileage are driven by plastic gears which just wear out. My trip mileage quit working long ago on my '88, and now the odometer sometimes takes a few miles before it rotates.
JohnO356 is offline   Reply With Quote
Old 01-30-2009, 08:40 AM   #7
cabinetman
Would it be safe to assume that that plastic gear is on the other end of the speedo cable? not the transmission end? there is nothing that goes to the back of the cluster, does it connect to the ECM?
Old 01-30-2009, 01:59 PM   #8
Scott68-93-97
Scott68-93-97's Avatar
speedo is electronic signal and theres a little motor that burns up that turns the odometer its easily replaced in the back of the cluster, this usually is caused by the tripometer freezing up putting drag on the odometer and frying the motor its actually common in the 88-94 trucks
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 01-30-2009, 08:20 PM   #9
cabinetman
Thanks for the help everyone. Now if you can tell me how to put more than 24hrs in a day I'll be set
Old 01-30-2009, 09:27 PM   #10
piecesparts
NOW ain't that the pits, we solve the guy's problems and now he thinks we are smart, too. Sheesh, you know that you will have to wait until daylight saving time to get more time.
