Old 01-27-2009, 12:07 PM   #1
69ROTROD
Best Disc Brake Conversion
So I am deploying to Bahrain in December and after a lengthy talk with the wife, I have approval to get my truck into "daily driver" status instead of buying a new truck when I get back.
I want to start a build list with approximate costs associated.
The truck already has a GM Goodwrench 350 with a Rochester quadra jet and flowtech headers. So that is pretty good.
I am seeking your wisdom with my plans...here is what I have currently.
1. Power disc brake conversion
2. Replace all brake lines
3. Professional exhaust (mines all clamps and cherry bombs)
4. Rebuild/refresh tranny (I am doing a filter/gasket change this spring but may want it pulled to do more when I get back)
5. Read diff inspection/flush.
6. Rear brake shoes/drums.
7. Radio install
I have thought of adding power steering but I am not sure what the cost would be...
Thanks for any advice you can give. I would also love to hear about any vendors that you recommend.
-Drew
1972 C/10!!!!!!!!!!!!!!!!!! NEW ADDITION!!
1969 C/10 LWB (Gone to greener pastures)
2006 Cadillac SRX
http://67-72chevytrucks.com/vboard/s...d.php?t=303768
69ROTROD is offline   Reply With Quote
Old 01-27-2009, 12:16 PM   #2
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Re: Best Disc Brake Conversion
Filters
Fuel lines
Flush gas tank
Tires
You ought to be able to get used PS parts here for $200. Another $60 at NAPA will get you fresh hydraulic lines and a v-belt.
PDB isn't real high on my project list. For a DD, I'm more about will it start outside reliably, does it have defrost and do the headlights work?
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 01-27-2009, 12:35 PM   #3
69ROTROD
Good call on the tires and fuel lines...I will definitely add those.
Headlights work and the only filter that needs to be replaced is the tranny.
Would it be worth doing a gas tank relocation?
I really want to do the disc brakes after I drove it from FL to Northern VA and had to deal with some DC area traffic. I don't want to have to constantly ride in the left or right lane in case I have to ditch b/c some prick cut me off...
If it helps, I am trying to keep this in the $7-8K range.
2006 Cadillac SRX
Old 01-27-2009, 12:43 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you want the best disc brake kit, Early Classic is your source. The other source is CPP, but lots of folks on here have complained about their lack of customer service, missing hardware, and other issues. There is none of that foolishness with Early Classic.
Old 01-27-2009, 01:24 PM   #5
steelhorse
steelhorse's Avatar
You can go to a boneyard and get the whole spindle setup from a 73-87.You will need to use the ball joints/tie rod from whatever year you get.
steelhorse is offline   Reply With Quote
Old 01-27-2009, 06:04 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you plan on lowering it you may want to check into getting a kit.The cost to rebuild calipers,replace rotors and so forth may be more than a kit.You probably need to evaluate your front suspension to determine how much will need to be replaced.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-27-2009, 06:13 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
73-87 conversion bits:
http://67-72chevytrucks.com/vboard/s...d.php?t=317654
texanidiot25 is offline   Reply With Quote
Old 01-27-2009, 06:39 PM   #8
heavy71chevy
heavy71chevy's Avatar
Not trying to hijack but whats bone yard 73-97 front ends usally go for....Ive thought about it before and just wasnt sure what the going rate is
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-27-2009, 09:03 PM   #9
texanidiot25
Eat My Rust
Varies by yard. But Scoti did the full crossmember swap for under 500
