Old 01-27-2009, 01:41 PM   #1
SWB
Active Member
SWB's Avatar
A New Member "CAB" question
Hi gang, let me start by saying it's great to be a member of this forum with great tips, info and deals. OK, I have a cab question on a project I'm getting ready to start. I have a 71 C-10 SWB with a rough cab, but recently bought a 68 C-20 (no motor/trans) with a rust free cab, it's a high hump w/4speed cab ( bare w/me I'm learning your correct terms ) will there be any issues with fit/alignment installing the 68 cab on the 71 Frame. Oh ya the 71 is a small block w/a powerglide, no air on either but the 68 cab has a powerbrake booster I plan to use on the 71, it had none. I'll take any/all input. Thx in advance...
*K10 SWB. Orange/White
*69 Ford F100 21K Actual Miles, 2nd owner in family since new
*67 Chevy II RestoMod, Wilwood all around,
Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc..
SWB is offline   Reply With Quote
Old 01-27-2009, 01:45 PM   #2
tim21391
tim21391's Avatar
Re: A New Member "CAB" question
only thing i think is the difference is the high hump transmission floor piece... unless the 68 is a high hump to..but i think its all the same..but i dont know much and might be different
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-27-2009, 01:48 PM   #3
fine69
fine69's Avatar
71 has a cable throttle. 68 is a rod.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 01-27-2009, 01:52 PM   #4
SWB
Active Member
SWB's Avatar
Thx ...The 71 cab I am removing is not a high hump. The 68 cab going on is a high hump
Old 01-27-2009, 08:40 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
use the 1/2 ton cab mounts, weld the hole in the high hump shut, and swap the throttle cable over with the cab and you'll be set.
You'll need the correct booster if you want to run power brakes. I've never been able to make a 3/4 ton drum/drum booster work on a disk/drum set up.
