Bretzke Racing Inc.
Just put my new AERO 52 series wheels on my 82, reusing my old 235/70/r15s...
what do you think i should do next? I debating whether or not to lower it some more...maybe like 3 more inches all around...right now it has one coil cut off of new springs up front, and homemade 2 inch shackles for the rear with the overload springs removed...i think it has a 2/4 or 2/3... Summit Racing (same place i ordered my wheels from) has 3 inch drop spindles for about $282 a pair, maybe those plus a homemade flip kit for the rear..another question i have is since my wheels are 15's...will i still be able use a 3" drop spindle...or do i need to go with something else to lower it?
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear) ![]() 2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12 ![]() ![]() "Expect the Un-expected" "Gas, Grass, Or Ass...No one rides for FREE!" ![]() |
Re: Tell me what YOU think...
has that nascar look !
slam it already 5/5...5/6
Leave it be.
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
agrees with lowering it ......do it !
Bretzke Racing Inc.
Thanks guys. I think im going to end up lowering it...but before i do that...i need to do a lot of research...especially if i might not be able to use these wheels with dropped spindles...
Before i drop it some more i really need to clean out the dual tanks and replace the sending units and all the fuel lines...it has a sputtering problem if i give it too much gas after 2nd gear...and, because the sending units have never been replaced...
looks good you should lower it.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
Generally you will have to trim your lower control arm when you use three inch spindles with 15 inch wheels.
74 swb 71 2wd Jimmy 82 2wd Blazer |
Happy to be here
![]() Join Date: Mar 2000
Lower it, get some lower profile tires, then have some pinstripe flames put on it in the same color is the wheel stripe...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-28-2009 at 01:21 AM. |
Happy to be here
Like this-
Chevys Kick A$$
I like it I would lower it more though and do something that matches the wheel stripe for sure
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#13 |
Cheyenne Super
#14 |
2WD 4 Life
like he said GENERALLY with 3 inch drop spindles you need to trim the control arms... it doesnt matter what brand they are its hit or miss....
I say lower it a little bit more. 2.5 inch drop spindles you shouldnt have any problems
Big D 1969 c10 1960 cadillac 1978 king cobra Last edited by N2TRUX; 01-28-2009 at 09:31 AM. Reason: Don't be rude! |
#15 |
I have a 6/6 drop on my truck. 3" drop spindle and 3" drop spring from djm. If you want to come on by we can see if your rims will fit. To me thats the only way of knowing forsure, throw them on and see what happens.
#16 |
Just lower the back alittle and level it up with the front......
Snap On Tools Dirt Racing PeterBilt And Chevrolets! |
#17 |
not my cup of tea.. but hey if you like it.. rock on.
#18 |
someday it will be done!
First get it running the way you want it.Get that 383 mentioned in your sig in it,then worry about stance,looks yada yada.If that's out of the question,then I'd say tuck the tread and level it a bit.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#19 |
I don't think these pills work
i also say slam it and off topic have ya'll seen this truck in this month's truckin its badass now that its all blacked out.
SQUARE84 ![]() 90 SUBURBAN |
#20 |
Living la vida broka
![]() Join Date: Jan 2003
Forget lowering for now, build a hot motor and do a SWB conversion with some duals exiting out in front of the rear wheels
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD 1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD 1984 C10 Longbed 6.2l diesel 700r4. ~SOLD 1985 GMC C20 350 700r4, ~under the knife |
#21 |
Bretzke Racing Inc.
Thanks for all your input guys! i really appreciate it!
But i think i have A LOT of thinking to do...especially if i want to goto Wyotech after i graduate from high school... ...all though i really would like a beasty small block to whoop some of my import trash talking friends' a$$'s! ![]()
#22 |
