Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-27-2009, 08:48 PM   #1
quickchevy
quickchevy's Avatar
Weight of truck is this about right?
Steer Axle 2220 LB Drive Axle 1420 LB Total 3640 LB Small Block Turbo 350 Does not have a wooden bed in it.Has a steal bed.Was like that when i bought it.
quickchevy is offline   Reply With Quote
Old 01-28-2009, 08:12 AM   #2
djracer
djracer's Avatar
Re: Weight of truck is this about right?
That's a little less than I would have thought. I crushed one back in the summer it was 3000 with no motor or tranny.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-29-2009, 10:04 PM   #3
pumpgas
pumpgas's Avatar
This truck went 4100lbs with me in it (170lbs).
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 01-29-2009, 11:28 PM   #4
whatnow123
whatnow123's Avatar
That's almost exactly what my truck tips the scales at minus 20 lbs. But I have a short bed, but AC, PS, 4 wheel disks (I'm told that disks are heavier than drums)
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-30-2009, 12:55 AM   #5
Super73
Super73's Avatar
Is this the 64-66 in your avtar pic? Were you in it? If so, I don't know why mine is soo flipping heavy.. On draglites, LS1/4L80E it was 3850 with a half tank me in it last time at the track.. However, I have moved a lot of weight around and it was 2,050 front and 1,800 rear.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-31-2009, 10:01 PM   #6
quickchevy
quickchevy's Avatar
Yes that is the truck.I was not in it.Taking it to the track and going to see what it weights there.That weight number is from a truck stop up the street.Will post the weight when i get back.
Old 02-01-2009, 06:45 PM   #7
Super73
Super73's Avatar
Don't forget to post some video and ET's...
Old 02-02-2009, 01:58 AM   #8
quickchevy
quickchevy's Avatar
Just went to weight it and help some friends out.But will hopefully have some video soon.Best so far is 9.1 1/8 @ 78.69 14.29 1/4 @ 94.30 lots of tire spine.
Old 02-04-2009, 01:32 PM   #9
Super73
Super73's Avatar
BTW, I was looking at some old files.. When I first put my truck together it weighed: 3,680-3,700 with out me in it. This weight came off a truck scale. I'm 190lbs so figure that at 3,870-3,890.
I went back after some minor things like taking the front bumper off and removing the heater it was 3,840 with me in it 2,260 front 58.85% and 1,580 rear 41.15%. This was with a fuel cell in the rear and before I moved the batterey.
Last time at the track with 1/2 tank gas it was 3,850 with 2,050 front and 1,800 rear. 53.25% front and 46.75 rear. Things that changed:
Batterey got moved to the back of the truck
Swapped out 7" steel wheels for Draglites
Went from a 275/50/15 front to a 195/75/15
Went from a 275/50/15 Drag radial to a 30x14.50 ET street with no tube
Swapped a manual steering box back in since someone had converter it to power.
Widened wheels tubs a little
Mounted the N20 bottle and 2 stage kit
Added aprox 100lbs to the upper portion of the tailgate
Next round of weight reduction I think will make some serious changes as far as weight, weight distribution and the way the truck is going to work. Changes are:
1 piece fiberglass front (Guessing it will shave 170-190lbs since the complete front with hood weighs 240lbs)
Getting rid of the brake booster (Guessing this is 10lbs)
Removed bench seat for lighter race seats (Saved 55-60lbs)
Removed gas tank bracketry (5lbs maybe)
Removing weight from tailgate (100lbs)
Putting in a 6 point cage (50-75lbs)
That would bring me to 3,585 with me in the truck.
Perhaps some of the above things are worth of doing to help your trucks balance.
Old 02-05-2009, 04:32 AM   #10
quickchevy
quickchevy's Avatar
Thanks for the info.How did the 275 50 15 DR look on the truck.Trying to find a used set to try out.
Old 02-05-2009, 10:45 PM   #11
GMC70c20
my 70 c20 weighed in at 4000 even. That was with a 350, sm465, but it also had a performer intake, headers, no power steering, no a/c or heater, no tail gate, and 4 wheel manual drums.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
