Old 01-27-2009, 09:14 PM   #1
Crumley
Crumley's Avatar
6" lift T-case drop?
I installed a 6" tuff country lift kit on my 72 GMC LWB. The kit came with a transfercase drop. When I installed the t-case drop spacer the angle of the engine (stock location), transmission and transfercase (1" lower) is quite steep (tilting down to rear of truck). The back of the t-case (opposite side of the front output shaft) is hitting the leading rearward edge of the t-case crossmember. Has anyone encountered this problem? How did you fix it? Or do you run your 6" lift kit without a t-case drop spacer?
Crumley is offline   Reply With Quote
Old 01-28-2009, 03:10 AM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: 6" lift T-case drop?
pictures? i am having a very difficult time getting a mental image fo what you are describing
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-28-2009, 05:34 AM   #3
Wreckless_71
Wreckless_71's Avatar
I get what you're saying but I don't get why you are running a drop spacer on a 6" lift. I know of 8" lifted trucks that don't have a drop spacer... Do you need the drop spacer???
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 01-28-2009, 06:54 AM   #4
Crumley
Crumley's Avatar
When I get a chance this evening I will post pictures.
I am not sure, thats why I have posted the question. If the t-case spacer isn't needed then I will remove it.
Old 01-28-2009, 10:25 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'd be surprised if you need to drop the t-case on that vehicle year with that amount of lift.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-28-2009, 11:04 AM   #6
Not using the spacer will fix it.I never understood why they think this would help.If the engine could be lowered,then it would make sense.
Old 01-28-2009, 01:23 PM   #7
Mudder
Mudder's Avatar
I had to lower mine because of a bad vib at hwy speeds. Dropped it an inch and it cured it.
Mudder is offline   Reply With Quote
Old 01-28-2009, 03:38 PM   #8
dammitmitchell
the pollock
mine i slowered and it helped a buut load with the driveshafts
Army vet 02-08
Old 01-28-2009, 06:29 PM   #9
Crumley
Crumley's Avatar
mudder and dammittmitchell how much lift are you running on your trucks? Was there a problem with the t-case hitting the backside of the crossmember? Any carb/engine problems due to the tilt of the engine?
Old 01-28-2009, 07:29 PM   #10
I lifted a longbed 6" and didn`t use the t-case drop because it would make the short little front d-shaft a sharper angle,which is more of an issue than the longer rear d-shaft,which would have it`s angle made more shallow from dropping the t-case.I ha to lengthen the rear shaft 2" and none to the front.A t-case drop also puts the motor into the firewall a bit more,which I don`t care for.
Old 01-28-2009, 07:41 PM   #11
CTENTA1
Registered 1971 K5
Thumbs up Re: 6" lift T-case drop?
Why not leave t-case w /out the spacers and if you have any problems with drivelines beeing short, how about geeting them extended. its the expensive way to do it, but its the correct way. I have 8" lift on my 71 blazer and thats what im doing. keeping t-case the same and just getting my drivelines extended.
CTENTA1 is offline   Reply With Quote
Old 01-28-2009, 11:37 PM   #12
dammitmitchell
the pollock
mine is basically aluminum tubed spacers (like gigantic washers)
i havent seen or felt any issues..
my truck will romp in and out of puddles without any driveshaft issues.. but i have my axles andfled upwards with those wedge shaped blocks..
Army vet 02-08
Old 01-28-2009, 11:38 PM   #13
dammitmitchell
the pollock
p.s. i also have mroe than 6 in of lift..
it's and estimated 8
Army vet 02-08
Old 01-28-2009, 11:57 PM   #14
Mudder
Mudder's Avatar
I dropped the crossmember 1 inch below the frame with an alumium block on each side. When I mounted my cab on the frame I made sure i had plenty of firewall clearence. I have a 6 inch lift now but had a 4 inch for a long time. I have altered drive shafts several times over the years.
Old 01-31-2009, 06:53 PM   #15
Crumley
Crumley's Avatar
Well I am splitting the differance on the t-case drop. There have been responses both ways concerning the t-case drop, so I installed the 1" t-case drop and made some 1/2" thick lift blocks out of teflon and installed them betweem the t-case mount bushing and t-case. So the t-case has a drop of 1/2". We'll see how well this works.
Old 02-01-2009, 05:12 AM   #16
dammitmitchell
the pollock
wow i wisy my t case had any color besides old grease and mud..
that's a pretty one
Army vet 02-08
Old 02-01-2009, 05:58 PM   #17
frostie_122
i didn't need a tcase drop on my 72 blazer w/ 6 inches. i extended and installed a cv joint. at 65-70 no irregular vibrations.
frostie_122 is offline   Reply With Quote
Old 02-04-2009, 09:37 PM   #18
edge
edge's Avatar
i'm getting ready to do the same thing, tuff country 6" and it came w/ the t/c 1" drop kit. i looked at a super lift 6" instructions i found on line and they do not come with a 1" spacer kit. but mention grinding clearance and the front drive shaft cv nubs on that end.
(mines a 85) i thought like you guys that just dont seem right to drop it down and then change the levelness of the other things...
i plan on not lowering it and checking carefully, till all is right.
anyone else chime in here...
edge is offline   Reply With Quote
