Junior Member
new to Drag Racing!!
Just wanted to see if most of you guys are running all stock, Modified, or full custom frames and rear suspesions. pics would help just trying to get a idea on which route to go!!
thanks
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol ![]() |
mini truck racer
Re: new to Drag Racing!!
I run a stock style suspension and a stock frame with aftermarket parts bolted in factory locations . I also don't have a fullsize that is my race truck .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
I have a modified stock setup. You can check my build thread in my signature It has lots of pics. Fair warning its long.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I, too, run the stock-style suspension with different shocks and springs front and rear. The factory trailing arm setup works very well in these trucks.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
![]() Join Date: Dec 2008
This truck the way it is piced would run 11.7 on motor and 10.9 on 150HP shot with a 406 sbc on 93 octane with factory stock susp parts.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
Stock rear suspension other than springs, shocks and home made adjustable lower control arm brackets (See thread)..
Front was stock other than shocks and springs, just made a new front crossmember but using factory control arms. Videos in sig. Should be a bit faster next time out.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Machinist
factory trailing arm and a set of coilovers...... so far so good... mines a little picky about staying in the groove or it will spin every time.... I have never even put slicks on it... That will help a ton im sure
