01-27-2009, 09:38 PM | #1 |
BOHICA
new frame?
Has anyone ever replaced the entire frame with one from a newer model? Is it even possible? I have 2 options an '81 or a '91. I planned on taking parts from one or both for a 5 lug disk upgrade on my 68 LWB. Could I just use the entire Frame? I understand there would be some fab involved, body mounts, bumper mounts etc. Other than that how do they line up as far as length, width, height. Any ideas are appreciated
01-29-2009, 11:35 AM | #2 |
BOHICA
Re: new frame?
Really? nobody has any input on this
01-29-2009, 12:58 PM | #3 |
Resident of Here
Re: new frame?
There is a member with a GMC X-cab he put on a 88-98 1-ton frame.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-29-2009, 03:00 PM | #4 |
Re: new frame?
Why would you? You can add disc brakes to your frame a lot easier than what you are asking about.
A lot more trouble than its worth.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
01-29-2009, 04:14 PM | #5 |
Re: new frame?
There's a guy in the projects section putting one on a 1990 1 ton 4x4 dually frame. It's gonna be SWEEEEEET!
http://67-72chevytrucks.com/vboard/s...d.php?t=280475
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half Last edited by bw4sale; 01-29-2009 at 04:17 PM. |
01-29-2009, 04:42 PM | #6 |
BOHICA
Re: new frame?
I have the donors available, and I plan a frame off anyway. I figured if the frames are nearly identical, all I have to do is some fab work it would save me some time, and I could upgrade to disk and 5 lug at the same time. Rather than pulling the parts of one frame just to put them right back on. Plus I could still drive my truck while I am shining up the new frame.
01-29-2009, 05:05 PM | #7 |
member #16
Re: new frame?
The wheelbase will be shorter on the 68. But the new can be shortened.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-29-2009, 11:39 PM | #8 |
its all about the +6 inches
Re: new frame?
if it is a 2 wheel drive, then stop thinking about it. You need a flat frame.
If it is a 4X4, then you can trim the frame down, relocate the rear axle forward and then build a custom made body lift to raise the cab to the height of the bed. Last edited by Longhorn Man; 01-30-2009 at 10:24 PM. |
01-30-2009, 12:13 AM | #9 |
Under Construction
Re: new frame?
I think i would just install the '81 front crossmember and rear-end on the '68... good luck with whatever direction you decide to go.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-30-2009, 10:02 AM | #10 |
BOHICA
Re: new frame?
Thanks for the info.
Longhorn man- it is a two wheel drive, thanks for the tip |
