01-27-2009, 10:15 PM | #1 |
Backup light switch for Borg T10 4 speed question ?
Going to do a tranny swap to a Borg Warner Super T10 tranny. There must be a kit to hook up the reverse lights but I can't seem to find any info on this. Shifter is a Hurst Competition Plus and correct linkage. There is a small hole on the reverse lever, maybe to hook a switch to ? I think something for a Muncie might works also.
Any help would be great, Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-27-2009, 11:31 PM | #2 |
Re: Backup light switch for Borg T10 4 speed question ?
I never realized that I have the same problem. I'll ask the 55 Chevy man at work tomorrow.
01-28-2009, 12:15 AM | #3 |
Member #1049
Borg Warner 4spds had a bracket and switch bolted to the side cover, and used a rod to go into the hole in the reverse lever,
01-28-2009, 08:57 AM | #4 |
Classic Industries has the backup switches and harnesses for the 4 speed manual transmissions. They are listed by year with different part numbers. I did not see the small rods listed but they may have them.
Here is a link: www.classicindustries.com Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-28-2009, 10:55 PM | #5 |
Livrat - thanks for the pics - all I can say is saawweeet ! I think that is what I am lookng for, any particular year that is from - where do I get one ???
And thanks JimK - I will look throught the catalogs.
01-28-2009, 11:30 PM | #6 |
"the other guy"
i also have a ST-10 w/ comp plus shifter, and i have bracket that bolts to the shifter mech and when you engage the rev lever, the arm on the shifter presses the switch and supplys ground to the circuit.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
01-28-2009, 11:35 PM | #7 |
Member #1049
I found those here:
http://www.show-cars.com/05-Clutch%20&%20Trans.htm Scroll down to four-speed backups. then look for 58 - 63 parts.. (GM went to Muncies in 64(... They do have 3 different switches listed but I think it will not matter as the only difference appears to be the wiring.. you will have to wire that up your self.. if your truck originally had a granny gear 4 spd, then you should have wires already down near the trans, look for two green ones.. light green and dark green. you should be able to connect the factory ones to the T-10 switch |
01-28-2009, 11:47 PM | #8 |
"the other guy"
thats not what i have, mine is from hurst and looks nothing like that? but hey... whatever works
http://store.summitracing.com/partde...5&autoview=sku
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" Last edited by vasquezmrysvll; 01-28-2009 at 11:55 PM. Reason: added link |
01-29-2009, 12:21 AM | #9 |
Member #1049
The ones I posted are the factory stuff.. the After market Hurst one is less $$ if it will work with the shifter you have
