01-28-2009, 10:27 AM | #1 |
It followed me home?
pics of 73-80 2 tone with no trim?
with any luck my crew cab will be off to paint in a couple weeks but I still havent decided on a color/s. Seems like replacing the trim is going to be pretty expensive and most arent happy with the aftermarket trim, so I've decided to go without. I'm considering going 2-tone but I'm not real sure what and where to break the paint with. So does anyone have pictures of 73-80 2 tones without trim I might be able to steal some ideas from?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-28-2009, 10:56 AM | #2 |
Slots go on anything!
Re: pics of 73-80 2 tone with no trim?
I think if you try to break the paint at the body line without the trim, it will look goofy. That's just an opinion, but I would think if you are going to can the trim, I would keep it a solid color. Since you are going to a shortbed, you should be able to piece the trim together relatively easy I would think.
01-28-2009, 11:07 AM | #3 |
The main problem (it's not a problem for some) is getting your color lines perfectly straight, especially in the front by the turn signal where it curves sharply twice. I saw one truck where he air brushed trim on the side of it. He painted on trim exactly like what came off and I thought it looked good.
01-28-2009, 11:26 AM | #4 | ||
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-28-2009 at 11:27 AM. |
01-28-2009, 11:32 AM | #5 |
Low & Fast!
Here some!
01-28-2009, 11:41 AM | #6 |
1962 C-10
Here's a few pics from my files...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-28-2009, 12:23 PM | #7 |
I had a Van years ago that we used the Pin stripes to break where the color changed without using a molding. It acted as a divider and help the eye so it didnot look out of place.
My Truck's not leaking its marking its territory! |
01-28-2009, 12:24 PM | #8 |
There was a guy on here that had a 77 with the 77 only yellow trim. He removed the trim, but painted a thin ochre yellow stripe along the body line where the trim used to be. Looked pretty good.
1977 GMC Sierra Grande Last edited by Pyrotechnic; 01-28-2009 at 12:24 PM. |
01-28-2009, 01:54 PM | #9 |
Not a custom job, but here is my old 82's factory 2 tone.
01-28-2009, 01:59 PM | #10 |
I like the one on the left. It's an '80 sport
01-28-2009, 10:25 PM | #11 |
Here are a couple that 19gmc63 did in the photoshop board. If I can figure out how/what to pinstripe it I think this is what I'll stick with
01-28-2009, 11:16 PM | #12 |
I like it
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
01-28-2009, 11:24 PM | #13 |
Yeah I was thinking about your truck when I saw that, hope you dont mind me stealing your colors too much.
01-28-2009, 11:48 PM | #14 |
I always wanted to paint a truck black and silver. I'm glad someone else likes that combo also. I have seen several black and silver trucks and liked most of them. I think its where you split the paint is what makes it stand out. I cant wait to see it when its done.
01-29-2009, 02:52 AM | #15 |
I like the one on the left too. The only thing I think I would do different is make the different color stripes narrower.
Say they are 1-1/2" to 2" each now, I would make them 1/2" to 3/4" each. It would be less "busy" but still give you the break.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-29-2009, 02:57 AM | #16 |
PS; I think the key to most of the trucks that have been posted is they are a single break.
The exception being the white & blue Suburban. It has two breaks; white/blue/white. That one looks to me like it is missing the trim?
01-29-2009, 09:42 AM | #17 |
I think I've seen that burb before and it has airbrushed trim.
01-29-2009, 11:02 AM | #18 |
I personally like both of the photochops. On a side note, about the Carter Hickman rendering toward the top of the page - is that blazer real? With the Ramcharger front end? At least I think it looks like a Ramcharger grill. If so, that's the coolest thing I've ever seen on a square body. Is it real, or just a rendering?
G to the M to the C......fool! RIP Jerry Reed "The Snowman" |
01-29-2009, 12:03 PM | #19 |
i used to have a pic of a truck that had airbrushed trim in stock style.you had to almost leave a snot trail to tell it wasn't real.spendy option though.the corvex trim kit's aren't that bad.just not as good as stock.mine's all corvex.no trim and a stock two tone look's just like a two tone with no trrim.in my opinion.
" Never look up a dead dogs butt." |
01-29-2009, 01:03 PM | #20 |
Luv the Crewcabs
Few i Have Saved..........
Not the 73-80 , But Same Body Lines........ Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
01-29-2009, 02:14 PM | #21 |
Not a 73-80 but a break in the two tone w/ 1/8" fine line in silver than black w/ silver met. flake between the silver stripes
01-29-2009, 03:57 PM | #22 |
awesome truck, anymore pictures?
01-29-2009, 07:26 PM | #23 |
Consider this for something interesting...
Don't put the trim on; however, have the custom painter airbrush on the trim. I once saw emblems that looked like the real thing except for the fact that they were flat airbrushed paintings, and it looked quite amazing. That would be a cool way to break up the two-tone.
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
02-04-2009, 01:36 AM | #24 |
Cheyenne Super
Air brushed trim.
02-04-2009, 11:50 AM | #25 |
that's the truck i was talking about........a good airbrusher is probably 75 bucks an hour.make's it a un-cost effective option unless you have deep pocket's or no somebody.
