01-28-2009, 01:32 PM | #1 |
front sway bar mounting
71 c10 LB, any reason I need to jack up the front end when mounting a sway bar and brackets, I can do easily with the truck on the gound, but wondering if the weight needs to be off the suspension
01-28-2009, 04:55 PM | #2 |
sway bar mounting
Hope im finaley in the correct forum now, Gonna order a fornt sway bar (LMC) unless someone could suggest somewere better to get bar and brakets, but my question is if I need to jack up the front end of my 71 c10 when mounting, I think I have enough room to work without lifting it but didnt know if the weight had to be of the suspension for correct mounting or if it mattered.
01-28-2009, 05:43 PM | #3 |
Re: sway bar mounting
Shouldn't need to, but you may have to jack up one side to help you get the end links lined up. If you're not sitting level a jack will definately help to get it together.
As far as where to buy, almost all the vendors carry sway bars. Just make sure it either includes the frame bracket, or get one seperately. |
01-28-2009, 06:15 PM | #4 |
The LuvShack Garage
Re: front sway bar mounting
I think this needs to be moved to the right section
I put mine on while the Jimmy was on the ground
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-28-2009, 06:42 PM | #5 |
Tot Roddin'
Check your local junkyard and the parts board. You will pay about a 1/4 of what any vendor is asking.
Best of luck!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-28-2009, 07:28 PM | #6 |
Nothing to see here.....
^^^^ what Nate said. several salvage yards I go to have 1-1/16" diameter bars (oem) on junkers. plunk down $20 for one of those, a set of Energy Suspension urethane grommets for $26, and a couple of grade 8 bolts and your gold.
And with that setup, you'll save mucho coin! http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 01-28-2009 at 07:34 PM. |
01-28-2009, 07:46 PM | #7 |
I agree with the junk yard suggestions. Hit a junk yard, spend a lot less $$, and have the same quality setup.
You could always drive the truck up on a couple of 2x8 blocks or similar. That would get the front a little higher for you but would keep the suspension "loaded". Edit: I should add, if you are lowered you can skip the frame "step" bracket and mount the sway bar bracket directly to your frame.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 01-28-2009 at 07:48 PM. |
01-29-2009, 06:48 PM | #8 |
Tot Roddin'
x2
