HERE.......Somewhere
Weird leak
inside the cab around the sunvisor bracket. I wonder what kind of rusting has happened to it.
Does anyone have this kinda problem non restored guys?
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
![]() Join Date: Nov 2007
Re: Weird leak
My c-20 had the headliner area kind of damp and surface rust because the po had a cb and the antenna was mounted on the roof. when I removed it it had a nasty hole with hammer marks to make the antenna fit. Its probly not the same but my parts truck cab had rust in the area youre describing. It seemed that the drip rail seam was the culprit. It was kinda ugly.
72 C20 Longbed 05 1500 Z71 |
![]() Join Date: Nov 2004
Re: Weird leak
What does your drip rail sealant look like?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: Weird leak
Does anyone have pics of this area being rusty or near gone?
Rottenwood Garage Member
Re: Weird leak
That is VERY common!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Insert Title Here
Re: Weird leak
here is mine
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Re: Weird leak
I took a leak on an electric fence one time ... that's the weirdest for me
Active Member
![]() Join Date: Jul 2007
Re: Weird leak
Very common problem on these trucks. The sealant cracks from age and water seeps under it. Since it's unseen, it works it's magic like a cancer. By the time you notice it (unless the previous owners were diligent) it's too late. Rust has already started...
Problem is, there's no repair panel for the topside. |
Re: Weird leak
Actually,the header panel is available.You need to stop the source in the drip rail.
Active Member
Re: Weird leak
Re: Weird leak
I hear mine rusting out on the driveway right now
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
Re: Weird leak
Yeah,just the piece the visors are mounted to.The outside is cut a patch,shape,and weld territory.
#13 |
Re: Weird leak
#14 |
Re: Weird leak
i had it about as bad as it can get, best to take care of it right now before it gets much much worse, the more water that leaks into that area the more other parts are going to get rusted out
here is how it looked before, it was horrid, 2 pieces after knocking out the rust, the paint was holding it together ![]() here is how i patched it after cutting away the rest ![]()
Active Duty Navy / Part time wanna be hot rodder? 89 Cressida w/ 408hp/674tq (with lots of wiggle room) ![]() 69 C-10 Project http://67-72chevytrucks.com/vboard/s...=1#post3066994 |
#15 |
Re: Weird leak
It isnt eat up there yet but maybe I can go ahead and get it done. There is slight rust which has been there a good while between the metal and the rubber gasket.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! Last edited by 70' GMC; 01-30-2009 at 07:35 AM. |
#16 |
Re: Weird leak
Spray some rust converter up in there.
#17 |
Re: Weird leak
since everyone said get that rust out so it wont eat through Ill spray rust converter on it or get the bottle and pour the entire bottle in it or let a body man go ahead and work on it before it gets bad. like work on the top area of the cab and back glass with new seals
#18 |
Re: Weird leak
I heard at the rumor mill that outer roof skins is/will be availible.
Still holding on to a bad ' 68 cab with a good roof though. I'll be damn if I don't have an ounce of rust but both front corners of my '70 roof is dented big time... Last edited by Kayotic; 01-30-2009 at 11:42 PM. |
#19 |
Re: Weird leak
Yeah Travis,get the outside tight and the rest will be ok.Condensation will be your only enemy,then.I`d spray converter to get all you can covered.Remove the visors and mirror.Soak some PB blaster first so the screws will back out ok and not take more metal with it.I`d put some other holes in there to spray a better area.Maybe some holes in the top,too.You can always plug the holes and install a headliner.
#20 |
Re: Weird leak
They are available and I think its southern kentucky classic parts and you have to call them cause they don't have it on their website.
#21 |
Re: Weird leak
OK, what would be a good route to go find a rust free cab that is like mine with the stock clearance lamps or fix that dag gone leak it only reminds to get it fixed only when it rains. Repair the retarded rust or get a better cab? I was thinking on the 72 GMC only for the front end and now patch panels the one I told y'all bout a few months ago. What route would y'all go fix my cab since it isn't eat through or find a better one. Which is going to be harder to find than a needle in a haystack
#22 |
Re: Weird leak
I would repair the retarded rust.
#23 |
Re: Weird leak
Since you have clearance lights that could be a cause of the leaks also.
#24 |
Re: Weird leak
would y'all keep the clearance lights on the cab or not cause I never see them at all like the stock ones? Should I keep em?
#25 | |
Active Member
Re: Weird leak
Since our trucks are 30+ years old, you have to find a restoration shop and the cost goes up exponentially to the desirability of the vehicle. At least it's what it seemed like to me. |
