01-28-2009, 10:52 PM | #1 |
steering wheel shake
k so i was cruising along the highway at 60 and i slowed to 50 and the steering wheel started to shake slightly, the truck stayed in a straight line. i clamped down on it with both hands using all my might to stop it but didnt affect it at all. im thinkin its either algnment or the tires arnt need to be balanced. other than that im not quite sure.
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
01-28-2009, 11:01 PM | #2 |
Re: steering wheel shake
Are you braking or coasting when this happens?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
01-29-2009, 12:01 AM | #3 |
this is a good question, i myself would lean toward a tire problem!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
01-29-2009, 01:02 AM | #4 |
It could be warped rotors if it happens when you're slowing down.That is if you have disk brakes up front.
01-29-2009, 02:14 AM | #5 |
If it happens when you are applying the brakes I would say warped rotors or rotors with hot spots.
The cure is to turn (resurface) the rotors or replace them. If you aren't hitting the brakes at the time I would lean towards loose steering or suspension pieces. Wide tires or deep reverse rims will usually magnify any front end issues a truck might have. An out of balance wheel/tire assembly will usually vibrate both accelerating an decellerating if the vibration is at a certain speed. I'd still check the wheels and tires out for damage, broken belts or signs of a weight being tossed off recently. Also if it gets driven on dirt check for a collection of mud in one spot on one or more wheel (s). |
01-31-2009, 03:10 AM | #6 |
happens when im coasting, accelerating, or crusing. but what stumps me is that it doesnt do it all the time. it has drums on the front, applying the brakes doesnt do anything. il probably take her to school this week and put the tires on the balencer, see if it helps or not
01-31-2009, 04:18 AM | #7 |
It's winter... when was the last time you checked your tire pressure?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-31-2009, 08:43 AM | #8 |
If it does it at certain speeds only I would look at balancing the tires. JMHO.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
